enen Posted August 5, 2019 Share Posted August 5, 2019 Hi All Im in the process of swapping from RHD to LHD. Little did I know of the 89-94 preface lift differences from the 95 onwards model. The dash being an obvious difference I have had to remove the wiring harness and swap it 180 degrees. This will probably reverse the operation of the turn signals? I found a '91 range rover wiring diagram in the rave manuals but havent found a 91 Disco wiring diagram. Does anyone know of one, or if the Range Rover and Disco wring would be the same on the turn signals? If anyone is interested in this project, I can post pics Thanks in advance Cheers Quote Link to comment Share on other sites More sharing options...
western Posted August 5, 2019 Share Posted August 5, 2019 Indicator stalk should still be down for Left indicators & up for Right indicators, regardless if left or right hand drive. Quote Link to comment Share on other sites More sharing options...
enen Posted August 5, 2019 Author Share Posted August 5, 2019 I dont think its that easy I still have more investigation to do but on the RHD car, the main harness exits a junction plug on the LH side firewall. I think this splits into a feed for left front and separate right front electrical. When i swap the harness to the LH firewall , im going to exit the RS firewalll and all the harness connections will need to be swapped side, for side. So my indicator lights will now be wrong?? Or am i over thinking it? Quote Link to comment Share on other sites More sharing options...
ballcock Posted August 8, 2019 Share Posted August 8, 2019 I understand what you are going to do, so why not just switch the wires at the switch? You will also need to alter any trailer plug to suit. Quote Link to comment Share on other sites More sharing options...
enen Posted August 9, 2019 Author Share Posted August 9, 2019 Hi Ballcock Yes, thats what i was thinking. I was hoping a wiring diagram may simplifly locating which wires are the left and right indicators Quote Link to comment Share on other sites More sharing options...
