Defender Posted August 6, 2019 Share Posted August 6, 2019 So I have just bought a new to me 300tdi 90 which has been apart and fully resprayed. When I was going down the motorway at 50ish in the rain, water is literally dripping on my feet and it seems the passenger floor is also wet. I guess there is some seal missing but none that are obvious I can see missing.......any ideas please? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 6, 2019 Share Posted August 6, 2019 18 minutes ago, Defender said: So I have just bought a new to me 300tdi 90 which has been apart and fully resprayed. When I was going down the motorway at 50ish in the rain, water is literally dripping on my feet and it seems the passenger floor is also wet. I guess there is some seal missing but none that are obvious I can see missing.......any ideas please? For the drivers side, any gaps around the pedal mounts? for the passenger side, bulkhead to heater seal? 1 Quote Link to comment Share on other sites More sharing options...
paime Posted August 7, 2019 Share Posted August 7, 2019 Check the windscreen hinges as well. You'll be able to see if the water is coming in by having a look just next to the A post. There will be some staining and probably rust if the seal has gone. 1 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 7, 2019 Share Posted August 7, 2019 And check the bulkhead to windscreen seal and the actual windscreen seal itself, both are common water ingress sites. Google Land Rover water ingress manual. HTH Mo 1 Quote Link to comment Share on other sites More sharing options...
Defender Posted August 7, 2019 Author Share Posted August 7, 2019 Thank you all for the suggestions, I will check these at the weekend. I was hoping that with it being apart that all seals had been replaced.....but maybe not! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 7, 2019 Share Posted August 7, 2019 Another one to look at.... the bulkhead vent seals ok? IIRC there are two different types. 1 Quote Link to comment Share on other sites More sharing options...
