blz6662 Posted August 9, 2019 Share Posted August 9, 2019 Hi Guys, I'm sure some of you have had this problem. First the Hybrid is a CA Chassis 86 with a 12L Suffix A Front Axle. Here's the problem, on rebuilding the front hubs I found I need an off-side half shaft Pt No. 606662 - Now unavailable although Rimmers offer an AEU2520P as a replacement. Therefore I bought this and guess what? Yes it's different and the bronze collar sits in a different place - grrr. Can't find a 606662 anywhere, what are the alternatives now everything is apart? Can I change the half shaft and cv joint & spacer to the EA Chassis onwards - Parts RTC5840 / RTC5843 / RTC5841. Do I need to change the stub axle as well? I assume the swivel ball is the same. I do have front and rear 24 spline diffs & shafts from a 1998 Disco 1 with ABS which I had ear marked for another project. If I'm forced to use these then what shafts, cv joints and stub axle do I need? Cheers Baden Quote Link to comment Share on other sites More sharing options...
missingsid Posted August 9, 2019 Share Posted August 9, 2019 Hi Baden, if you need Suffix A half shafts I have some from an axle I have split up last year. PM me if I need them? Marc Quote Link to comment Share on other sites More sharing options...
blz6662 Posted August 9, 2019 Author Share Posted August 9, 2019 Hi Marc Did you get my pm - just checking Baden Quote Link to comment Share on other sites More sharing options...
