bongtodd Posted August 12, 2019 Share Posted August 12, 2019 (edited) Hi All, I'm in the middle of a complete rebuild after the chassis rusted apart, so I took the opportunity to get a new galavanised chassis and added the brackets for a second fuel tank. This is a Defender 90, with 200TDI Engine. So my problem is the rear exhaust section, I have a standard down pipe standard middle, and due to the second fuel tank can not fit the standard rear, and can not find any standard parts to exit straight out. Also I have no welding skills, so need to find an off the shelf or a custom exhaust maker, but wondering if anyone has any recommendations or ideas... been stuck at this point for ages so really want to get on to the next issue.... Edited August 12, 2019 by bongtodd forgot to type Quote Link to comment Share on other sites More sharing options...
Arjan Posted August 12, 2019 Share Posted August 12, 2019 Have a look at the other exhaust systems. I have a Ninety here and when we fitted the system nay years ago it was, I think, a 200 or a 300 Tdi system with plenty of space in the rear between rear axle and crossmember for the tank... Quote Link to comment Share on other sites More sharing options...
bongtodd Posted August 12, 2019 Author Share Posted August 12, 2019 (edited) This is the TD5 rear going through the gap and the 200tdi middle at the bottom... the rear 200tdi goes through the braket on the left of the photo, not sure what the rear 300tdi is like but will it marry up with the 200tdi middle or is it a complete replacement... Edited August 12, 2019 by bongtodd Quote Link to comment Share on other sites More sharing options...
bongtodd Posted August 12, 2019 Author Share Posted August 12, 2019 This one shows the braket a little clearer Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted August 13, 2019 Share Posted August 13, 2019 You absolutely have to use the td5/Puma rear. The 97-98 300tdi tailpipe looks like it allows loads of room for the rear tank but it fouls the tank when in place. The 300tdi system marries up to the td5 tailpipe with a small adaptor piece but unfortunately I haven’t owned a 200tdi since early 2000s so can’t help on what is needed. Quote Link to comment Share on other sites More sharing options...
bongtodd Posted August 13, 2019 Author Share Posted August 13, 2019 Thanks I’ll take a look at that.. 200tdi downpipe 300tdi centre td5 tail... quite a frankinstein exhaust!! Anyone ever married those up on a 200tdi chassis!! Quote Link to comment Share on other sites More sharing options...
