boaterboy Posted August 13, 2019 Share Posted August 13, 2019 I've been told that a ball joint dust cover at the lower end of the front suspension on my D2 TD5 is deteriorating. Please could someone help me identify what & where this part is? Also, is it a safety critical item and how easy would it be to replace? Thank you very much in anticiation of your help. Quote Link to comment Share on other sites More sharing options...
Blanco Posted August 13, 2019 Share Posted August 13, 2019 They look a bit like this...https://www.ebay.co.uk/itm/UNIVERSAL-TRACK-ROD-END-BALL-JOINT-RUBBER-DUST-BOOT-COVERS-GAITERS-2X/182729866045?hash=item2a8b8c7b3d:g:fA8AAOSwxzBZndZF Found on all the ball joints,.... steering arm, track rods etc. When the cover goes the grease dries out, then the dirt and water get in and dramatically shorten its life. Usually people just change the ball joints but if you have greaseable ball joints that you have kept in good shape then replacing the boot is probably worthwhile. Splitting the balljoint can be a challenge, be sure to clean the threads before removing the locknut. HTH Quote Link to comment Share on other sites More sharing options...
bear Posted August 14, 2019 Share Posted August 14, 2019 Hi, You can see the layout here http://new.lrcat.com/#!/1232/35470/35580/2694 Trust me that you are going to have a fight to get the steering knukle off to replace the ball joints and the ball joints themselves. A YouTube search will give you some idea. Griff Quote Link to comment Share on other sites More sharing options...
boaterboy Posted August 15, 2019 Author Share Posted August 15, 2019 Thank you, Blanco, for your reply which gave me a good start and to you, bear, for the actual parts drawing. Excuse my ignorance but is the knuckle part no 1 in the drawing? Also, any recommendations wrt the best supplier / manufacturer of the ball joints, please? Quote Link to comment Share on other sites More sharing options...
bear Posted August 16, 2019 Share Posted August 16, 2019 The steering knuckle is the large part - number 1. I always try and buy genuine LR for these types of parts as I don't want to be doing them again in a long time. Griff Quote Link to comment Share on other sites More sharing options...
boaterboy Posted August 16, 2019 Author Share Posted August 16, 2019 No doubt wise words, bear. Thank you. Quote Link to comment Share on other sites More sharing options...
