gerty99 Posted August 14, 2019 Share Posted August 14, 2019 Hi All, New to this forum. So not sure if I'm posting in the right place but your help and advice would be very much appreciated ! just had all brakes and brake slave cylinder replaced ( have one reservoir that feeds both brakes and clutch. The brakes are fine, but when you select any gear and let the clutch out it takes a couple of moments for the vehicle to move ??? any ideas ! Best Regards Quote Link to comment Share on other sites More sharing options...
steve b Posted August 14, 2019 Share Posted August 14, 2019 It sounds like a sticking piston in the clutch slave cylinder - the 2A is very different to a Series3 though . Welcome to LR4x4 , you will find it an interesting and useful source of LR tech of all sorts cheers Steve b Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted August 14, 2019 Share Posted August 14, 2019 3 hours ago, gerty99 said: Hi All, New to this forum. So not sure if I'm posting in the right place but your help and advice would be very much appreciated ! just had all brakes and brake slave cylinder replaced ( have one reservoir that feeds both brakes and clutch. The brakes are fine, but when you select any gear and let the clutch out it takes a couple of moments for the vehicle to move ??? any ideas ! Best Regards Does the peddle come back as expected, if yes, replace the flexi hose between the slave and the clutch itself. It may have collapsed internally. £8 fix if that's the culprit Quote Link to comment Share on other sites More sharing options...
artwigwa Posted August 15, 2019 Share Posted August 15, 2019 On 8/14/2019 at 1:58 PM, 2a-Egg said: Does the peddle come back as expected, if yes, replace the flexi hose between the slave and the clutch itself. It may have collapsed internally. £8 fix if that's the culprit Had the same problem with my series, replaced flexi and all was good. Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted August 19, 2019 Share Posted August 19, 2019 On 8/14/2019 at 10:22 AM, gerty99 said: Hi All, New to this forum. So not sure if I'm posting in the right place but your help and advice would be very much appreciated ! just had all brakes and brake slave cylinder replaced ( have one reservoir that feeds both brakes and clutch. The brakes are fine, but when you select any gear and let the clutch out it takes a couple of moments for the vehicle to move ??? any ideas ! Best Regards Any luck? Quote Link to comment Share on other sites More sharing options...
