kevin50 Posted August 14, 2019 Share Posted August 14, 2019 (edited) Well this is the bit I've been Dreading. Rebuild of 1987 110 which was Originally 2.5 na I think. But now 300Tdi from Discovery on to LT77 Box.Anyway got to stage to Rewire, I did not take this thing apart, was bought as Rolling Chassis so did not see where wires were.The Loom through Chassis plugs in to Bulkhead with all wires matching up as in first pic. I think the other plug to the Right is the for the Main Engine Loom from looking at other posts ect, please correct me if I'm wrong. Rest of pics are wires from 300 engine,Ive looked at loads of the Diagrams out there but for the life of me just cant understand themI know there is a Load more Inside doe the Dash ect but gonna start on Engine first.Any info Greatly Appreciated .Thanks Edited August 14, 2019 by kevin50 add Quote Link to comment Share on other sites More sharing options...
Arjan Posted August 14, 2019 Share Posted August 14, 2019 Looking good - love the galvanized chassis ! Can't help with the wiring I'm afraid - I make my own very much not standard wire looms. Quote Link to comment Share on other sites More sharing options...
western Posted August 14, 2019 Share Posted August 14, 2019 Rubber moulded connectors are pre 1991 200tdi vehicles they changed to plastic casing when 300tdi came in, just buy some new male & female connectors & replace the ones that don't match, have a look at Land rover-connectors ebay shop, you can message him via ebay for advice. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 14, 2019 Author Share Posted August 14, 2019 19 minutes ago, western said: Rubber moulded connectors are pre 1991 200tdi vehicles they changed to plastic casing when 300tdi came in, just buy some new male & female connectors & replace the ones that don't match, have a look at Land rover-connectors ebay shop, you can message him via ebay for advice. If I knew where the plastic ones joined up to the rubber ones I would but they seem to be different colours. The rubber ones that I have already joined match up perfect with same colour each side, but the Plastic plugs on 300 engine are different colours so not really got a clue where they go. Thanks for ebay will have a look at his shop. Quote Link to comment Share on other sites More sharing options...
western Posted August 15, 2019 Share Posted August 15, 2019 300tdi wiring diagrams here, shouldn't be much difference between disco & defender as they both use the same engine Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted August 15, 2019 Share Posted August 15, 2019 I've fitted a 300tdi engine into my 1989 110 that was a 2.5td. I connected the 300 loom to the original plug so can still disconnect it easy when I need to remove engine. Can get pics later if needed. Hopefully it will show what colour cables go where. If you not got the engine loom you can remove plug and either hard solder cable extensions or better option a new multiway plug Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 15, 2019 Author Share Posted August 15, 2019 3 hours ago, Tim2809 said: I've fitted a 300tdi engine into my 1989 110 that was a 2.5td. I connected the 300 loom to the original plug so can still disconnect it easy when I need to remove engine. Can get pics later if needed. Hopefully it will show what colour cables go where. If you not got the engine loom you can remove plug and either hard solder cable extensions or better option a new multiway plug Thanks Mate pics would be Great if you can. Cheers Kevin Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted August 19, 2019 Share Posted August 19, 2019 (edited) Sorry it slipped my mind. Just had a look and where I had an issue with previous owners wiring burning out when I remade the loom I taped it up so cannot see colours easy. The cables each side of plug are the same so we can work out off wiring diagram what colour does what. Edited August 19, 2019 by Tim2809 Error Quote Link to comment Share on other sites More sharing options...
kevin50 Posted September 2, 2019 Author Share Posted September 2, 2019 (edited) Still on with this, I know I shouldn't but I keep jumping from one job to another without finishing. Anyway found the Origional loom, and plug lines up perfect to Bulkhead plug matching all colours. Ive numbered wires in first pic, Think I know what goes to Starter and what goes to Alternator, But not sure about the rest. Edited September 2, 2019 by kevin50 Quote Link to comment Share on other sites More sharing options...
monkie Posted September 2, 2019 Share Posted September 2, 2019 It's hard to see all of the colours on your picture but I think it is the following: 1 main terminal to loom 2 starter motor terminal 3 alternator 4 oil pressure sensor 5 coolant temp sensor 6 and 7 I can't make out the wire colours but I am missing the stop solenoid terminal on the fip. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted September 2, 2019 Author Share Posted September 2, 2019 (edited) 30 minutes ago, monkie said: 2It's hard to see all of the colours on your picture but I think it is the following: 1 main terminal to loom 2 starter motor terminal 3 alternator 4 oil pressure sensor 5 coolant temp sensor 6 and 7 I can't make out the wire colours but I am missing the stop solenoid terminal on the fip. 6 is 2 Green going in to one plug. and 7 I think White as it has faded. Edited September 2, 2019 by kevin50 Quote Link to comment Share on other sites More sharing options...
western Posted September 2, 2019 Share Posted September 2, 2019 fuel shutoff solenoid is white/grey trace. coolant temp sender is green/blue trace. number 6 if it same colours as the temp sender at thermostat housing, is a unused connection for the pre tdi engines when it was located on the top rear left of cylinder head. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted September 2, 2019 Author Share Posted September 2, 2019 7 could have been white / grey but has faded. 4 I'm sure is white / Brown 6 Two Green The only two spade connectors I can see on that side are , one on Oil filter housing, and one on Injection Pump. Quote Link to comment Share on other sites More sharing options...
western Posted September 3, 2019 Share Posted September 3, 2019 200tdi wire colours & where they go on here, same as for 300Tdi Quote Link to comment Share on other sites More sharing options...
monkie Posted September 3, 2019 Share Posted September 3, 2019 I rebuilt the engine loom for my 1988 110 with a 19J. I have looked up the wiring colours for the loom I made, I'm quite sure the 2.5NA loom is very similar if not the same: Solid Brown (thick) - supply from Alternator to main bus on startermotor White with red trace - to starter motor solenoid (from starter relay) White with grey trace - fuel shut off Green with blue trace - coolant temp sender Black with white trace - oil pressure switch Brown with yellow trace - alternator I'm sure I didn't have the unused green wires in my original loom and I certainly don't now! Quote Link to comment Share on other sites More sharing options...
kevin50 Posted September 3, 2019 Author Share Posted September 3, 2019 (edited) 2 hours ago, monkie said: I rebuilt the engine loom for my 1988 110 with a 19J. I have looked up the wiring colours for the loom I made, I'm quite sure the 2.5NA loom is very similar if not the same: Solid Brown (thick) - supply from Alternator to main bus on startermotor White with red trace - to starter motor solenoid (from starter relay) White with grey trace - fuel shut off Green with blue trace - coolant temp sender Black with white trace - oil pressure switch Brown with yellow trace - alternator I'm sure I didn't have the unused green wires in my original loom and I certainly don't now! That's just what I waned to see Mate as I am hopeless at using Colour codes and Charts., I'm positive colours om my loom are exact same as yous ,will check tomorrow. Now these are the Main ends of mine in pics. Pic 1 is Starter, now there is altogether 4 brown wires as you can see going in to a pair of Ring connectors, Do both these go on the same Main Starter connector with Live to Battery lead in Pic 2 ?? Pic 3 is Alternator , this also has two brown do these two join together to connect to Alt ? the other wires are further back up the line. added pic of Alternator, Where do wires attach to it ?? Might have to lengthen some to make them reach. Edited September 3, 2019 by kevin50 Quote Link to comment Share on other sites More sharing options...
monkie Posted September 3, 2019 Share Posted September 3, 2019 Okay I think I get where you are coming from.... The alternator terminals are different on the 300tdi to your 2.5 NA. You need to cut off the plastic plug from your loom and fit ring terminals. This is from memory so I'm more than happy to be corrected on this....... The two thicker brown wires connect to the bigger terminal on your alternator to supply the main positive bus on the starter to the circuits and battery. The thinner brown with yellow trace wire fits onto the middle terminal and the third terminal has nothing as that was for the rev counter I think. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted September 3, 2019 Author Share Posted September 3, 2019 29 minutes ago, monkie said: Okay I think I get where you are coming from.... The alternator terminals are different on the 300tdi to your 2.5 NA. You need to cut off the plastic plug from your loom and fit ring terminals. This is from memory so I'm more than happy to be corrected on this....... The two thicker brown wires connect to the bigger terminal on your alternator to supply the main positive bus on the starter to the circuits and battery. The thinner brown with yellow trace wire fits onto the middle terminal and the third terminal has nothing as that was for the rev counter I think. Thanks. Do the four Brown all go together on Starter Main Connector too? Quote Link to comment Share on other sites More sharing options...
monkie Posted September 3, 2019 Share Posted September 3, 2019 8 minutes ago, kevin50 said: Thanks. Do the four Brown all go together on Starter Main Connector too? Yes that's right. 2 of which are from the alternator and the other 2 go to feed the other circuits, one is the main feed to the ignition switch and the other for the glow plugs if I remember correctly. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted September 3, 2019 Author Share Posted September 3, 2019 22 minutes ago, monkie said: Yes that's right. 2 of which are from the alternator and the other 2 go to feed the other circuits, one is the main feed to the ignition switch and the other for the glow plugs if I remember correctly. Great Think Ive Grasped it now, Please forgive me everyone but This is my first Rebuild, and my Main problem is that I did not take it apart as I bought it as a rolling Chassis with Crates full of Parts which I am still sifting through as I come to stage when they need fitting. Thanks Everyone for help. Quote Link to comment Share on other sites More sharing options...
monkie Posted September 4, 2019 Share Posted September 4, 2019 8 hours ago, kevin50 said: Great Think Ive Grasped it now, Please forgive me everyone but This is my first Rebuild, and my Main problem is that I did not take it apart as I bought it as a rolling Chassis with Crates full of Parts which I am still sifting through as I come to stage when they need fitting. Thanks Everyone for help. Glad it's helped, no shame in asking questions. Good luck with the rebuild Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 4, 2019 Share Posted September 4, 2019 Kevin, persevere with trying to understand the wiring diagrams. It's confusing at first but practice makes perfect. It helps to concentrate on one bit of the diagram, for example, the alternator, follow the wiring where it goes and you'll start to understand what the different elements do. Electricity will no longer be electrickery 😊 Mo 1 Quote Link to comment Share on other sites More sharing options...
