Mo Murphy
Thoughts on greasing the release bearing tube
Do you grease it when changing the release bearing ?
What grease do you use ?
Mo
Share this post
Link to post
I use copper grease.  It has always worked so far, but there may be better alternatives.  I thought the copper would continue to act as a lubricant and rust inhibitor after the grease died out, hence not using moly.  Graphite grease should do the same.
  • Like 1
Share this post
Link to post
It gets a smear of bearing grease whenever I’ve done mine, along with everything else that moves in there.
  • Like 1
Share this post
Link to post
Thanks Gents, someone else also recommended copper grease !
Mo
Share this post
Link to post
I use copper grease too, but I notice that LUK sell a special grease for the purpose. Don't know what it is though.
  • Like 1
Share this post
Link to post
Recon gearbox Chris, would be foolish not to replace the clutch whilst I'm in there 😊 so yes undoing the catalan engineering !
Mo
  • Like 1
Share this post
Link to post
According to SACHS,..
Quote
Not every lubricant is suitable. It needs to be temperature-resistant and endure high surface loading. Unsuitable lubricants can become liquid, solidify, become resinous, or burn, and thus cause malfunctions.
Every SACHS clutch kit is supplied with a lubricant pad which is sufficient to lubricate the hub splines once. This high-performance grease optimally meets requirements.
https://www.sachsperformance.com/en/sachs-service-greasing-clutch-disc-hub-spline
I am going to be changing the clutch on my D2 soon and will be using Loctite 8009 or NEVER-SEEZ Nickel compound, whichever I find first in my garage.
  • Like 1
Share this post
Link to post
Cheers Johnno,
In the end my new LOF clutch came supplied with a syringe full of their recommended lubricant.
Mo
Share this post
Link to post
