Green200tdi Posted August 17, 2019 Share Posted August 17, 2019 HI, so I’ve fitted mazda RX8 seats in my 110 all went well with passenger seat as it’s manual but the drivers seat is electric and does everything it should except move back and forward both pins at the motor are live🤔 ( I find bit strange) wired in as Thick grey, 12v thick purple, earth blue, heated seat (not using at mo) all working but back and forth🙄 any ideas? Quote Link to comment Share on other sites More sharing options...
Lightning Posted August 17, 2019 Share Posted August 17, 2019 If both pins of the motor are showing live, it means that the circuit is earth switched. I assume the motor has a live feed on one of the pins, if you connect the other pin to earth the motor should run. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted August 17, 2019 Author Share Posted August 17, 2019 44 minutes ago, Lightning said: If both pins of the motor are showing live, it means that the circuit is earth switched. I assume the motor has a live feed on one of the pins, if you connect the other pin to earth the motor should run. All all I know is that if you live the grey and earth the purple it should all work Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted August 18, 2019 Author Share Posted August 18, 2019 Well they are in looking and feeling great, still no sign of back and forward motor working but can live with that for now, mind you removed one of the runners to find what I thought was the problem always the way never an easy fix 🙄 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 18, 2019 Share Posted August 18, 2019 Very tidy 👍 Mo Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 19, 2019 Share Posted August 19, 2019 Can you still access the under seat lockers with these seats? Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted August 23, 2019 Author Share Posted August 23, 2019 On 8/19/2019 at 9:42 AM, Gazzar said: Can you still access the under seat lockers with these seats? you can and you can't, if i want to change a fuse on the td5 under seat fuse box thats ok get your hand in there if you want to remove one of the batterys seat out but all batters no days are no maintenance so din't really matter tbh jump starting id use Anderson plug outside the vehicle so its win win Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 23, 2019 Share Posted August 23, 2019 That's a shame, my lightweight has under seat tanks, and under seat fillers, so they're out. Nevermind. Thanks! Quote Link to comment Share on other sites More sharing options...
Badger110 Posted August 23, 2019 Share Posted August 23, 2019 Nice colour combo with the carpet 👍 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted August 25, 2019 Author Share Posted August 25, 2019 On 8/23/2019 at 7:17 PM, Badger110 said: Nice colour combo with the carpet 👍 Don’t worry the carpet is going in the bin going black 👍 1 Quote Link to comment Share on other sites More sharing options...
