Maffnich
Range Rover classic suspension help
Hi all,
I need some opinions,
i have a 1994 Range Rover classic 300tdi manual and I had bought a couple of years ago with 2”lift. Unfortunately the suspensions are hard and it doesn’t have the Range Rover soft ride.... I would still like to keep the lift on it but should I swap the suspensions to medium or wouldn’t  it really make a difference ??
Share this post
Link to post
You could use suspension spacers instead of longer springs, and then use standard range rover classic springs. Remember that with the softer springs, you’ll get more roll, and with the extra height you may not find this desirable. One way to find out though 😀
Share this post
Link to post
First thing, why do you need the lift? Removing that and going back to standard springs will make it ride much nicer.
  • Like 1
Share this post
Link to post
Or fit air springs which will give you the choise of ride height and comfort as the need arises.
Share this post
Link to post
