neilc Posted August 19, 2019 Share Posted August 19, 2019 (edited) If I add a blade fuse box (mini) and power it from existing ignition wire how can I then spur that off to more than one new electrical item ? , I've tried my best to explain in the diagram , thanks. Initially I will only be running a dual usb from this and don't really at this time known what else I will be running off it , it is just for future reference . I will also at some time try to exchange the under column glass fuses for another blade fuse setup. VID_20190817_153823738.mp4 Edited August 19, 2019 by neilc Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted August 19, 2019 Share Posted August 19, 2019 You'll have to fit the spades with double wires - ie first one has source + feed to 2nd - 2nd has feed for 3rd as well and so on. Quote Link to comment Share on other sites More sharing options...
Romahomepete Posted August 19, 2019 Share Posted August 19, 2019 You could use something like this Quote Link to comment Share on other sites More sharing options...
neilc Posted August 19, 2019 Author Share Posted August 19, 2019 I appreciate the early Am responses from you both , thanks. I'll have a look at that , I've already bought the fusebox , I've only just thought that to tidy it up a bit I could drill out one of holes in the spade connector and fit these , or buy a new mini fuse box where the connections screw in Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 19, 2019 Share Posted August 19, 2019 Perhaps a bit late if you've already bought the fuse box but bussed ones exist and are quite handy; Example: https://www.ebay.co.uk/itm/153482834535 Quote Link to comment Share on other sites More sharing options...
