CLANCY Posted August 22, 2019 Share Posted August 22, 2019 Hi Guys I have a 1996 Defender 90csw. Today the Clutch pedal went to the floor. I then pulled it up and now it's solid will not move.Me thinks I need a new clutch.Is there anyone in my area that could fix it. I could put it inside my barn if power or light is required.Any other suggestions welcome. My Post code is PO7 4RA I am hoping not to be off the road for long? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 22, 2019 Share Posted August 22, 2019 Most likely scenario is a failure of the clutch release mechanism, probably the pivot punching through the clutch fork. Either way the gearbox and engine need splitting so you'll be putting a full clutch etc. in anyway. Can't help with fixing it I'm afraid but if you've got an engine crane, or can borrow one, it's not too difficult a job. There's a guide in the tech archive. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 22, 2019 Share Posted August 22, 2019 There's West4x4 at Waltham Chase, Keith Gott at Alton, or if you've got a barn and something that can lift an engine it's fairly DIYable. Might be worth an ask on the ShireLRC Facebook group or just pop up Portsdown hill this evening to Mick's Monster Burger as we're gathering up there for a burger and chin wag Edit: I might be able to lend you an engine crane, especially if you could collect it this evening. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 22, 2019 Share Posted August 22, 2019 And don't just fit a new clutch fork or the same thing will happen again. Weld a reinforcement to the place where the pushrod wears out the fork. Then it will last for ever. Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 22, 2019 Share Posted August 22, 2019 Brittanica Restorations in Ontario (he’s actually a Yorkshireman expat) does a very good fork mod using a nylon bearing, much like the everlasting Series III forks, Mail order. I don’t know how costly or quickly he could get one to you, but it’s a better mod than the usual flat bar or washer welded behind the pivot point. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted August 22, 2019 Share Posted August 22, 2019 Check the pivot too. Quite often they wear through the arm as the wear on the pivot has made a sharp lip around the edge. Quote Link to comment Share on other sites More sharing options...
CLANCY Posted August 22, 2019 Author Share Posted August 22, 2019 Thanks for all the advice so far, still ploughing through my options (Good deal on fork may buy @ £50 from Britannica) Quote Link to comment Share on other sites More sharing options...
garrycol Posted August 23, 2019 Share Posted August 23, 2019 Not all that relevant to the issue, but when I lived in the UK many, many years ago I lived in East Street Hambledon - was a great little village that used to have a small garage at the northern end - was able to work on my V12 Etype but is probably not there any longer. Garry Quote Link to comment Share on other sites More sharing options...
CLANCY Posted August 23, 2019 Author Share Posted August 23, 2019 Thanks for that Garry.Unfortunately Long gone. Quote Link to comment Share on other sites More sharing options...
CLANCY Posted August 24, 2019 Author Share Posted August 24, 2019 On 8/22/2019 at 12:03 PM, FridgeFreezer said: There's West4x4 at Waltham Chase, Keith Gott at Alton, or if you've got a barn and something that can lift an engine it's fairly DIYable. Might be worth an ask on the ShireLRC Facebook group or just pop up Portsdown hill this evening to Mick's Monster Burger as we're gathering up there for a burger and chin wag Edit: I might be able to lend you an engine crane, especially if you could collect it this evening. Thanks for that I have contacted West 4x4 Waltham Chase as thats near.Unfortunately he is away until Tues 27th Quote Link to comment Share on other sites More sharing options...
CLANCY Posted September 6, 2019 Author Share Posted September 6, 2019 Thanks Guys for all the helpful advice.Job now done had new clutch and reinforced fork fitted. Fork had failed. Quote Link to comment Share on other sites More sharing options...
