ianmayco68 Posted August 24, 2019 Share Posted August 24, 2019 Hi all, just looking into my smoke issue on the defender 200tdi trying to undo the bolts in the thermostat housing and all 3 broke off , I’ve drilled them out but is it best to re tap them out or drill out to 6mm and fit a nut and bolt to stop it happening again . Thoughts please. Cheers ian Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 24, 2019 Share Posted August 24, 2019 Helicoil, and a suitable anti seize compound? I think the coil inserts are less prone to corrosion than the aluminium castings. Quote Link to comment Share on other sites More sharing options...
western Posted August 25, 2019 Share Posted August 25, 2019 Helicoil inserts are normally stainless steel based. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 25, 2019 Author Share Posted August 25, 2019 Cheers both , think I’ll leave the helicoils if there stainless . It’s not been a good weekend apart from hurting myself on numerous occasions, then this happened and to top it all the crankshaft gear is stuck on and 2 of the bolts on my puller broke off in the threaded holes on the gear , so waiting for a mate to come over this morning with some heat to try that , but it’s all good fun and I’m definitely getting drunk later at a barbecue we’re going to. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 25, 2019 Share Posted August 25, 2019 They have a way of fighting you sometimes don’t they 😐 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 25, 2019 Author Share Posted August 25, 2019 Yes been spending too much time with the project, so now she’s getting her own back . Quote Link to comment Share on other sites More sharing options...
