Dharris Posted August 28, 2019 Share Posted August 28, 2019 Hi would anyone be able to tell me how to remove the seals from the ace valve block ? As when I got mine someone had replaced the pipes but not the seals and it’s leaking. Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 28, 2019 Share Posted August 28, 2019 Try the Discovery forum - RR don’t have ACE as far as I know. Quote Link to comment Share on other sites More sharing options...
Dharris Posted August 29, 2019 Author Share Posted August 29, 2019 RR do have it they just call it something else Quote Link to comment Share on other sites More sharing options...
walace58 Posted August 29, 2019 Share Posted August 29, 2019 What actually is it and what does it do? Quote Link to comment Share on other sites More sharing options...
walace58 Posted August 29, 2019 Share Posted August 29, 2019 What vehicle is it fitted to (yours!)? Quote Link to comment Share on other sites More sharing options...
Dharris Posted August 29, 2019 Author Share Posted August 29, 2019 2011 Range Rover sport 3.0 d hse Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 30, 2019 Share Posted August 30, 2019 ACE is Active Cornering Enhancement. It is a hydraulically actuated torsion bar (similar to an antiroll bar) that is electronically adjusted to keep the front suspension level. It was fitted to 7seat Discovery IIs which had rear EAS but coil sprung fronts. RRC and P38 had EAS on all four corners, so the EAS would compensate for roll. This is the first time I have heard of ACE in relation to any RR. Quote Link to comment Share on other sites More sharing options...
Dharris Posted August 30, 2019 Author Share Posted August 30, 2019 They don’t call it ace on a RR they call it Dynamic suspension Quote Link to comment Share on other sites More sharing options...
walace58 Posted August 31, 2019 Share Posted August 31, 2019 Perhaps it looks bodged because the prev. owner fitted it? Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 31, 2019 Share Posted August 31, 2019 4 hours ago, walace58 said: Perhaps it looks bodged because the prev. owner fitted it? Unlikely - it’d be a hell of a job with all the wiring and ecu. I thought the EAS would negate the need for ACE, but then again, the Sport is meant to have sharp handling... Quote Link to comment Share on other sites More sharing options...
walace58 Posted August 31, 2019 Share Posted August 31, 2019 My son works for an established Land Rover independent garage. He tells me ACE is an option for RRs. However experience is they last about 3 years and the seals are not replaceable. So replacement is the only option. However take a lot of time and effort to replace depending on model. So labour costs can be quite high. Expensive, they usually recommend to customer to fit standard antiroll bar 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 1, 2019 Share Posted September 1, 2019 I know a lot of D2 owners remove the ACE and rear EAS because of recurring reliability issues. Quote Link to comment Share on other sites More sharing options...
walace58 Posted September 1, 2019 Share Posted September 1, 2019 I eventually had to give in and fit coils to my. 94RRC Quote Link to comment Share on other sites More sharing options...
