2a-Egg Posted August 28, 2019 Share Posted August 28, 2019 So I'm thinking of making sure the plate in the cockpit is actually the right one. Which means finding the number on the spring hanger. My truck is 52 and the chassis has paint on it. So I'm thinking thinners to get it down to metal.. But then what, because 52yrs it's not going to be pretty and just show me the stamped number. Ideas anyone... Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 29, 2019 Share Posted August 29, 2019 Paint stripper. Wire brush. Then take a rubbing, cover with thin paper and gently rub with soft pencil until the number appears. Then apply a good zinc based primer, coat with several layers of paint. And finally, a good anti corrosion product, dinitrol/bilt hamber whatever. Assuming it's the original spring hanger? Worth it? Quote Link to comment Share on other sites More sharing options...
Romahomepete Posted August 29, 2019 Share Posted August 29, 2019 Do you mean S2 or 52 (80" S1) the numbers are in different places. Also if it is ex mil it could be somewhere different. Peter Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted August 29, 2019 Author Share Posted August 29, 2019 1 minute ago, Romahomepete said: Do you mean S2 or 52 (80" S1) the numbers are in different places. Also if it is ex mil it could be somewhere different. Peter It's an S2a and is 52yrs old. After a Web search online from the plate on the bulkhead it came up as dispatched to a dealership in Nottingham. Was just going to see if they matched up. Quote Link to comment Share on other sites More sharing options...
steve b Posted August 29, 2019 Share Posted August 29, 2019 Peter Where would ex-mil be stamped ? I thought everything post S1 was stamped on OS dumb iron ? cheers Steve b Quote Link to comment Share on other sites More sharing options...
garrycol Posted August 29, 2019 Share Posted August 29, 2019 The chassis number should be stamped on the rear passenger side spring hanger Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted August 29, 2019 Author Share Posted August 29, 2019 1 hour ago, garrycol said: The chassis number should be stamped on the rear passenger side spring hanger Ive been told front?? Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 29, 2019 Share Posted August 29, 2019 If it's 52 years old, it was made in the late sixties, so chassis number will be on the spring hanger of the front spring, I think. Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted August 29, 2019 Author Share Posted August 29, 2019 (edited) 3 minutes ago, Gazzar said: If it's 52 years old, it was made in the late sixties, so chassis number will be on the spring hanger of the front spring, I think. It rolled off the line on the 14th August 1967. I have got most of the paint off, can see bare metal and a bit of rust, but no clear sign of numbering. It looks like the original part, or a damn good welder replaced it... Also I'm looking at the front nearside hanger Edited August 29, 2019 by 2a-Egg Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted August 29, 2019 Author Share Posted August 29, 2019 (edited) Not looking promising, not seen any sign of a stamp or engraving. Edited August 29, 2019 by 2a-Egg Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 29, 2019 Share Posted August 29, 2019 That's where it should be on a series 3, but I think it can be elsewhere on a 2a. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 29, 2019 Share Posted August 29, 2019 Though is that welding on the dumb iron above? Try on the chassis rail proper, above the bit where you are looking now. Quote Link to comment Share on other sites More sharing options...
garrycol Posted August 29, 2019 Share Posted August 29, 2019 I found an old 67-71 2a chassis in the bush 2 weeks ago and its number was as I indicated - the passenger rear - likewise another earlier series 2 I inspected for club registration was also on the passenger rear. I think series 1s are up the front somewhere, and my 101 is the front drivers side. Does it really matter as it will only take 5 minutes to have a look on all spring hangers - it doesn't need to be hard. Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted August 29, 2019 Author Share Posted August 29, 2019 3 minutes ago, garrycol said: I found an old 67-71 2a chassis in the bush 2 weeks ago and its number was as I indicated - the passenger rear - likewise another earlier series 2 I inspected for club registration was also on the passenger rear. I think series 1s are up the front somewhere, and my 101 is the front drivers side. Does it really matter as it will only take 5 minutes to have a look on all spring hangers - it doesn't need to be hard. Why make it easy though hahaha Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted August 29, 2019 Author Share Posted August 29, 2019 30 minutes ago, Gazzar said: Though is that welding on the dumb iron above? Try on the chassis rail proper, above the bit where you are looking now. Think there has been work on the iron, front of it. Quote Link to comment Share on other sites More sharing options...
Romahomepete Posted August 30, 2019 Share Posted August 30, 2019 Military ones tend to be but not always on the rear spring hangers inside or out front or back. UK civilian ones are on the outside of the front offside dumb iron. I have seen an ex australian military chassis with the number on the outside of the nearside rear spring hanger. Peter Quote Link to comment Share on other sites More sharing options...
missingsid Posted August 30, 2019 Share Posted August 30, 2019 Some S1 (mine) have the number on the rear near side. Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted August 30, 2019 Author Share Posted August 30, 2019 So basically it could be anywhere haha Quote Link to comment Share on other sites More sharing options...
garrycol Posted August 31, 2019 Share Posted August 31, 2019 No - it will be specific for the model you have - have you spent 5 minutes of your life and checked the other locations - if it is not on the other spring hangers it will have been where there welding has been done. Its not all that hard. Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted August 31, 2019 Author Share Posted August 31, 2019 5 hours ago, garrycol said: No - it will be specific for the model you have - have you spent 5 minutes of your life and checked the other locations - if it is not on the other spring hangers it will have been where there welding has been done. Its not all that hard. Alright.. I'm actually in London for a wedding this weekend. And if you read back I think my comment in jest ( the haha gives that away) about it being on any one of the hangers.. Jeez didn't know I had to be so serious about it. And no its not hard at all... Maybe I'll spend 10 minutes just incase I'm stupid and can't find it... Quote Link to comment Share on other sites More sharing options...
