Cornish Rattler Posted September 3, 2019 Share Posted September 3, 2019 Hi guys Right as you may know i'm more or less at the end of the rebuilt inc a Disco 200tdi conversion as well and we are fitting the new wiring loom atm from Autosparks which is for a negative earth car which mine is but had a dynamo fitted and the fitted 200tdi engine has a new B P alternator fitted but I just need to know what I need to do to convert from dynamo to alternator please Quote Link to comment Share on other sites More sharing options...
steve b Posted September 3, 2019 Share Posted September 3, 2019 Did you get the alternator spec loom or a standard 2a dynamo spec. ? Steve b Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted September 3, 2019 Author Share Posted September 3, 2019 11 hours ago, steve b said: Did you get the alternator spec loom or a standard 2a dynamo spec. ? Steve b Alternator spec loom, i also have the h/d cable that links the alternator to the starter motor as well Quote Link to comment Share on other sites More sharing options...
steve b Posted September 4, 2019 Share Posted September 4, 2019 Nothing to do to convert from dynamo to alternator with the new loom and HD charge wire , just connect it all up as per the wiring diagram. cheers Steve b Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted September 5, 2019 Author Share Posted September 5, 2019 Oh right cheer's Quote Link to comment Share on other sites More sharing options...
