Snowbird Posted September 8, 2019 Share Posted September 8, 2019 I have replaced the rear tub cross rails and have found out how poorly these were put together.The mounting holes in the floor are not equal. The mount on one side is 3/8" further back than on the other. Should I just bolt the new cross frames where the old ones were or should I drill new holes to square up the frames? Quote Link to comment Share on other sites More sharing options...
lo-fi Posted September 8, 2019 Share Posted September 8, 2019 I think it probably depends what makes you happy. Either not drilling extra holes, or knowing that it's all straight. It's a classic Land Rover conundrum. Quote Link to comment Share on other sites More sharing options...
Snowbird Posted September 9, 2019 Author Share Posted September 9, 2019 Hi lo-fi I think as long as the rubber pads sit on the 6 pads that are on the chassis, then I will leave well alone. If not I'll drill new holes and square everything up. That will just leave empty holes in the floor which I can fill with a pop rivet. Thanks Quote Link to comment Share on other sites More sharing options...
lo-fi Posted September 9, 2019 Share Posted September 9, 2019 Sounds like a solid plan Quote Link to comment Share on other sites More sharing options...
