Sill bars with tree rails
white90
Hi Tony,
Looks pretty sweet.
If you don't mind me asking where did you get your external roll cage from?
Are they expensive (probably yes) and can you get plans etc to make them up?
My old man works for a blacksmith...... :D
Cheers
Grant
I cut it off
the front hoop was welded to the bulkhead out rigger and the sill bars previously fitted.
I cut the plate off the sill bar with a 1mm grinding disc.
the cage is now only attached to the bulkhead out rigger
I will be fitting wing bars early this year and when I do I may re do the outrigger /rollcage connection.
to see the same cage in action with the same chassis connections look in the video section for Jules accident
where he back flipped his T/C.
his cage was originally the same as mine(mine was copied from his and his brothers)
the cage was a good price at the time and has been fine.
If I were to buy another I'd use North off road in Stockton on Tees Shaun does A1 work and will
fit/build whatever you want.
to close this thread for me
the bars performed as they were intended on Saturday at the winch challenge
took some hard knocks and were dragged aound loads of trees
they undoubtedly save the sides of the 90 repeatedly
I wish I had fitted them sooner.
plus the powercoating is unmarked which I'm impressed with giving the knocks they were getting.
££ well spent for once :)
