Abs, tc, Park brake light on dash
So today the defender decided to put these lights up. Red parking brake light orange abs and orange tc. Before I start looking at all the wires for the abs is this a common problem. Like just low brake pads? Checked brake fluid levels and that's fine.
This is from a 2.4 puma model double cab pick up with 49000 miles on the clock
Thanks
Edited by western
Title changed to text subject
I believe these are known as the '3 Amigos' in some circles.... I had these showing on my TD5 and managed to get rid of them by cleaning all the earthing points thoroughly. I think on the Puma there are some other possible faults including hill descent wires and brake pedal switches but i might be wrong.
Yep, Three Amigos, often (though not only) caused by the shuttle valve failing in the ABS unit.  There are quite a lot of YouTube videos showing how to fix that, but before you do, just check the basics, like sensor gaps and getting the fault code read by a diagnostics computer, or you could spend a lot of time and money on the wrong thing.
