Rear double cardan propshaft.
Wanting to fit a double cardan prop to the rear of my D1 based RTV trialer. The phasing of flanges on T/box and diffs is not right any more, at the front I have fitted standard D2 front prop and larger T/box flange. But the rear is not so strait forward, changing to the larger flange would require machining of the hand brake drum etc. So apart from spending around £500. with Gwyn Lewis, is there another way. I see a lot on the forum about front props and double cardan  joints but can't find much on rear's. Although for trialing the set up fine I drive to events some times, but vibration between drive and over run above 30mph is worrying.
Get an adaptor plate made up? Think wheel spacer... I reckon 1/2 - 3/4" thick should do it. It's simple enough, and could easily be made in a home shop if you have access to a lathe and pillar drill, or would be a cheap job at any local engineering firm for cash.
As suggested I think the adaptor plate would be the easiest way. On the original donor vehicle the transfer box flange was facing down app 6 degrees and the diff flange up the same amount, so in phase, no vibe's. However the T/box flange is now vertical and so out of phase with diff flange. All 90's and Disco's are out of phase on the front prop, but can be improved by fitting a double cardan to the shaft, which i have done. So want to try same on the rear.
my 110 is out off phase on the front axle , you have to clock the driveshaft for being out off phase (there are 2 arrows on the driveshaft that need to align, i think there's 45 degrees between flanges)  you can do the same with your rear drive shaft .
undo the rear drive shaft  , pull out the flange and put it back 1 spline apart from what it was , do a testdrive and adjust further if need be, i bet that solves the problem .
see this old posting :
Edited by hurbie
On my tomcat with a standard prop on the rear I used to get vibration on over run. My tomcat had the engine shifted back 10 inches, enough to swap front and rear props on a 100 inch wheel base. When I built it I re-phased the the rear prop to suit the front location and vice versa. I fitted a front double carden prop on the rear (re-phased to suit rear location) this solved the vibration.
Mike
  • 2 weeks later...
Update. I tried turning the rear prop one spline at a time as suggested by Hurbie, but made no noticeable difference to vibration, thanks for your idea though. So decided to purchase a ready made shaft. Dunning + Fairbank made me a double cardan shaft with standard L/R flange sizes, fitted it today and happy days, all vibe's and strange noises gone.
  • Like 1
