monkie Posted October 7, 2019 Share Posted October 7, 2019 I gather that the 19J and the 200 tdi both use the Garrett T2 turbo. If this is correct, will a CHRA for a 200 tdi fit into a 19J turbo correctly? Quote Link to comment Share on other sites More sharing options...
western Posted October 7, 2019 Share Posted October 7, 2019 Nope, different turbo's on those engines but yes both are Garrett units. TD = T2 200Tdi = T25 Quote Link to comment Share on other sites More sharing options...
monkie Posted October 7, 2019 Author Share Posted October 7, 2019 5 minutes ago, western said: Nope, different turbo's on those engines but yes both are Garrett units. TD = T2 200Tdi = T25 Thanks Ralph. I'm on thin ice here as I'm getting my info off of Wikipedia... My understanding is 19j and 200tdi use the T2 and the 300tdi uses the T25. Is this fake news? 😁 Quote Link to comment Share on other sites More sharing options...
western Posted October 7, 2019 Share Posted October 7, 2019 The above info is from my Defender workshop manual, Wikipedia is incorrect not sure which model the 300tdi uses as I don't have anything with the specs in. Quote Link to comment Share on other sites More sharing options...
monkie Posted October 7, 2019 Author Share Posted October 7, 2019 Darn it, I was hoping you had the 200 and the 300 mixed up, but I just checked it too and you're are absolutely correct. So, anyone know who can supply a CHRA for a T2 on a 19J? 1 Quote Link to comment Share on other sites More sharing options...
hurbie Posted October 7, 2019 Share Posted October 7, 2019 (edited) quick google found this : https://www.turborebuild.co.uk/webshop/cat_1245946-Defender.html bearing housing seems to be the same : https://www.turborebuild.co.uk/webshop/prod_3590911-4353500006-Garrett-T2T25T28-Turbo-Bearing-Housing.html Edited October 7, 2019 by hurbie Quote Link to comment Share on other sites More sharing options...
monkie Posted October 7, 2019 Author Share Posted October 7, 2019 26 minutes ago, hurbie said: quick google found this : https://www.turborebuild.co.uk/webshop/cat_1245946-Defender.html bearing housing seems to be the same : https://www.turborebuild.co.uk/webshop/prod_3590911-4353500006-Garrett-T2T25T28-Turbo-Bearing-Housing.html I saw that too but it states it fits the defender 2.4 tdci. My 19J is 4 generations behind that engine. I don't think it is the right part. Quote Link to comment Share on other sites More sharing options...
hurbie Posted October 7, 2019 Share Posted October 7, 2019 24 minutes ago, monkie said: I saw that too but it states it fits the defender 2.4 tdci. My 19J is 4 generations behind that engine. I don't think it is the right part. just scroll down 🙂 1 Quote Link to comment Share on other sites More sharing options...
monkie Posted October 7, 2019 Author Share Posted October 7, 2019 9 minutes ago, hurbie said: just scroll down 🙂 Doh! Thanks for that link, I think I saw that Web page about 4 times and didnt scroll down 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 8, 2019 Share Posted October 8, 2019 I used the compressor and turbine housings from a 19J and the core from a 200Discovery on my 200. Worked a treat. Quote Link to comment Share on other sites More sharing options...
monkie Posted October 8, 2019 Author Share Posted October 8, 2019 23 minutes ago, Snagger said: I used the compressor and turbine housings from a 19J and the core from a 200Discovery on my 200. Worked a treat. This is why I asked the question, from the link it seems the CHRA is common to both. I have asked them for confirmation. Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 8, 2019 Share Posted October 8, 2019 I think they had different oil pipe unions, so be wary of that. 1 Quote Link to comment Share on other sites More sharing options...
monkie Posted October 8, 2019 Author Share Posted October 8, 2019 Thank you, I shall question this also. Quote Link to comment Share on other sites More sharing options...
monkie Posted October 9, 2019 Author Share Posted October 9, 2019 Turborebuild.co.uk responded. There are two types of chra used on the 19j T2 turbo either 452005 or 466842. The type used is given on the ID tag next to the oil feed fitting. Quote Link to comment Share on other sites More sharing options...
