simonr Posted January 2, 2007 Share Posted January 2, 2007 After a lot of research, the joint with the largest angle of movement that I can find in the uk is: GM/Vauxhall BA0804 / QR3167S Which allows 37 degrees free movement in either direction. The thread on the taper is M12 x 1.5 pitch and on the shank is Female M14 x 1.5mm pitch. Both Right Hand. Since nobody seemed to be able to answer this question - I thought it would be a good thing to put on file! Si Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 2, 2007 Share Posted January 2, 2007 Good tech Si - where did you find the specs, is there a "big book of ends" or even a website? Could be handy to know. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted January 3, 2007 Share Posted January 3, 2007 Interesting tech. M14 is a little small though, i'm on M24 and i've still bent one. Quote Link to comment Share on other sites More sharing options...
simonr Posted January 4, 2007 Author Share Posted January 4, 2007 John, Sadly, the angle isn't quoted. Even if you talk to a very helpful chap at Q&H, they have no idea! The only answer is to go to a shop & start opening boxes (A pack of choccy HobNobs does wonders). Interesting tech.M14 is a little small though, i'm on M24 and i've still bent one. You may be right - and on the joints intended to take a radial force, I intend adding an additional stop behind the cup to prevent it moving - just to be on the safe side! Si Quote Link to comment Share on other sites More sharing options...
