SimonSJC Posted October 9, 2019 Share Posted October 9, 2019 (edited) Folk New to this but bought myself my dream 110 which will require lots of work! 1984 sealed beam unit replaced and upgraded to a halogen. Before I started headlight and sidelights all work grand until full beam when the NS headlight goes out. Side lights still work and the light bar on the roof goes on but no idea. I've checked bulbs etc all good and tried to check as much of the wiring as possible up through the wing and whilst old seems ok. Any help is appreciatedas it'll be an MOT failure. Thanks Simon Edited October 9, 2019 by SimonSJC Spelling mistake Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 9, 2019 Share Posted October 9, 2019 Checked the fuses? Quote Link to comment Share on other sites More sharing options...
western Posted October 9, 2019 Share Posted October 9, 2019 Check the earth point & connections behind each set of front lights, earth wires are bolted to forward face of the inner wing edge. Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted October 10, 2019 Share Posted October 10, 2019 Run a temp live feed to headlight terminal to check it does work. Had this on mine, turned out it was a break in the wire, in the loom, somewhere behind the heater box. Cut and spliced a new length in, and been ok now for 9 years. Quote Link to comment Share on other sites More sharing options...
SimonSJC Posted October 10, 2019 Author Share Posted October 10, 2019 Right ok off in Sunday so will try all above and let you know how I get on thanks for the replies. Quote Link to comment Share on other sites More sharing options...
SimonSJC Posted October 15, 2019 Author Share Posted October 15, 2019 Ok so checked the fuses all appear ok and finally got a hand from my son to turn lights on and off. Noticed when I touched the full beam light to either terminal on the bulb other than the negative the spot light bar came on but not the main beam. I'm thinking it's a wiring fault when and whenever the spot lights were put on. I can here something clicking inside the cab with the bonnet open and I'm at the front. Any further ideas. By the way headlight works fine on OS so no issues with bulbs etc. Thanks again Quote Link to comment Share on other sites More sharing options...
SimonSJC Posted December 3, 2019 Author Share Posted December 3, 2019 (edited) Right finally sorted. Appears a wire was going to a relay that didn't go anywhere! Auto spark found it in 10 minutes! Thanks for all the help. Edited December 3, 2019 by SimonSJC Spelling mistake Quote Link to comment Share on other sites More sharing options...
