chubby5 Posted October 11, 2019 Share Posted October 11, 2019 Looking for help! I converted my 1986 2.5 na defender to a TDI with a Discovery 200 TDI engine about 10 yrs ago. now I am moving to Spain to retire, i am rather attached to my 110 having bought it direct from the Military 14 yrs ago and done many modifications to it. I have started converting to left hand drive. but have come across a problem that the steering column and the Turbo clash. The only way round this I can see is change the manifold and turbo to a defender one which are hard to find. Anyone have another solution or parts for sale Quote Link to comment Share on other sites More sharing options...
Pappa Smurf Posted October 11, 2019 Share Posted October 11, 2019 Look at what LHD 300tdi defenders do. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted October 11, 2019 Share Posted October 11, 2019 Rotating the turbo and fitting a straight shaft (without the collapsible joint) is one solution. It's tight, but it works. Quote Link to comment Share on other sites More sharing options...
hurbie Posted October 11, 2019 Share Posted October 11, 2019 on my 110 LHD , they removed the collapsible joint , and fitted a straight shaft . if you want i can make some pictures tomorrow Quote Link to comment Share on other sites More sharing options...
chubby5 Posted October 11, 2019 Author Share Posted October 11, 2019 58 minutes ago, hurbie said: on my 110 LHD , they removed the collapsible joint , and fitted a straight shaft . if you want i can make some pictures tomorrow Thanks, some pictures would be really helpful, if possible could you measure the length of the shaft as i think it would need to be longer. thanks for the help Quote Link to comment Share on other sites More sharing options...
western Posted October 11, 2019 Share Posted October 11, 2019 looking at the 110 parts book, it doesn't list a one piece or collapsible shaft for left hand drive vehicles see page 448 in http://www.retroanaconda.com/landrover/parts_books/110/5_axles_suspension_steering_p398-471.pdf even lrparts.ru doesn't say if any are LHD or RHD http://cat.lrparts.ru/?category=118540 Quote Link to comment Share on other sites More sharing options...
hurbie Posted October 12, 2019 Share Posted October 12, 2019 i believe the shaft is the same for LHD/RHD , on my car they removed the collapsible joint and welded the 2 remaining bits together , reinforcing with a piece of tubing. not my favorite solution , but as you say defender manifolds are hard to find. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 12, 2019 Share Posted October 12, 2019 19j manifolds are relatively plentiful though ... Mo Quote Link to comment Share on other sites More sharing options...
monkie Posted October 12, 2019 Share Posted October 12, 2019 50 minutes ago, Mo Murphy said: 19j manifolds are relatively plentiful though ... Mo I think the studs are in a different place on the 19J. I was thinking of putting a defender 200tdi inlet manifold on my 19J for intercooling but Ralph pointed out this problem. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 12, 2019 Share Posted October 12, 2019 ... or does the tdi just have more studs ? Got to be worth a punt to find out. All you need is a manifold gasket monkie 😊 Mo Quote Link to comment Share on other sites More sharing options...
western Posted October 12, 2019 Share Posted October 12, 2019 9 studs on 19J manifolds, 11 studs on 200tdi manifolds Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 12, 2019 Share Posted October 12, 2019 There is also a consideration to be had in the fact that the shaft is collapsible for a reason. Quote Link to comment Share on other sites More sharing options...
western Posted October 12, 2019 Share Posted October 12, 2019 Disco 1 shaft might work http://cat.lrparts.ru/?category=83679 Quote Link to comment Share on other sites More sharing options...
hurbie Posted October 13, 2019 Share Posted October 13, 2019 13 hours ago, Retroanaconda said: There is also a consideration to be had in the fact that the shaft is collapsible for a reason. i know , i'm not to happy with this modification ....it was on the car when i bought it ... Quote Link to comment Share on other sites More sharing options...
Landy7 Posted October 16, 2019 Share Posted October 16, 2019 I have a military 110 LHD with a disco 200TDI that I've fitted myself 2 years ago. Not sure how I tackled this issue but will take some pics. Quote Link to comment Share on other sites More sharing options...
chubby5 Posted October 17, 2019 Author Share Posted October 17, 2019 On 10/12/2019 at 4:31 PM, hurbie said: i believe the shaft is the same for LHD/RHD , on my car they removed the collapsible joint and welded the 2 remaining bits together , reinforcing with a piece of tubing. not my favorite solution , but as you say defender manifolds are hard to find. thanks for the help and photo's . my turbo seems at a completely different angle can it be turned that amount or is yours a different turbo, i have attached photo as can't see that i can turn turbo? Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted October 17, 2019 Share Posted October 17, 2019 3 hours ago, chubby5 said: my turbo seems at a completely different angle can it be turned Yes. There is a big (strong) circlip that you need to remove. Pipework might need some reworking afterwards. Quote Link to comment Share on other sites More sharing options...
monkie Posted October 17, 2019 Share Posted October 17, 2019 I'd get some new tubing for your waste gate actuator while you are there. It looks a bit cracked. Quote Link to comment Share on other sites More sharing options...
