Beanie Posted October 15, 2019 Share Posted October 15, 2019 Hi Recently purchased a winch bumper for my 90 but the mounting brackets don't align with the chassis?? Am I missing something obvious or is the wrong one for the vehicle? I purchased it off Ebay off of another defender. Help please. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 17, 2019 Share Posted October 17, 2019 Well the bumper obviously needs to be stood up straight and then perhaps the two vertical bolts will fit? Sadly it appears that the bumper you bought doesn't use the lashing eye bolt holes too to make it a 6 bolt attachment which is preferable but not he end of the world. 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted October 17, 2019 Share Posted October 17, 2019 Assuming as bish says it will stand up straight then a shim will be required. Mike Quote Link to comment Share on other sites More sharing options...
Badger110 Posted October 18, 2019 Share Posted October 18, 2019 Quote Link to comment Share on other sites More sharing options...
winchman10 Posted October 20, 2019 Share Posted October 20, 2019 Might need to add shims to take up the gap I assume you are using the correct grade of bolts and not the original bumper bolts? I have seen several home made bumpers fail, some badly manufactured others with the wrong grade bolt in Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted October 20, 2019 Share Posted October 20, 2019 1 hour ago, winchman10 said: I assume you are using the correct grade of bolts and not the original bumper bolts? Care to share what grade they should be? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 20, 2019 Share Posted October 20, 2019 8.8 is plenty. Quote Link to comment Share on other sites More sharing options...
winchman10 Posted October 22, 2019 Share Posted October 22, 2019 (edited) On 10/20/2019 at 9:59 PM, UdderlyOffroad said: Care to share what grade they should be? Any I made and sold had a full set of stress calcs and from memory 10.9 high tensile, but that was my bumper, any manufacturer should have the bolt size and grade in the instructions, as they should also have a file with the info in incase of any insurance claims. I was lucky as a good friend can do the calcs and produced the correct paperwork. In my experience I have seen bumpers fail but also a chassis come apart as it had been poorly repaired, they are not rocket science to make but like most things a no win no fee bloke can upset the apple cart very easily. Remember the bolts should not be studs and should not be threaded all the way up to the head as these are weaker A local lifting gear place can easily test it for you for a few quid. The big issue is are they lifting equipment or not? But that's another can of worms, you see a winch with a load rating but not a bumper? Edited October 22, 2019 by winchman10 Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted October 23, 2019 Share Posted October 23, 2019 On 10/20/2019 at 10:21 PM, Bowie69 said: 8.8 is plenty. +1 This is what we look for in competitions for recovery points, including bumper fitting. 10.9's would obviously be even stronger. Quote Link to comment Share on other sites More sharing options...
