liams105e Posted October 15, 2019 Share Posted October 15, 2019 Hi, I've bought a 1994 TDI Disco, the previous owner removed the tow bar. I've got another from a 1997 V8 Disco, this has the electrics with it. where on the TDI will I find the part of the loom to connect the 7pin plug to? I'm assuming that they will be compatible. The Haynes manual isn't much use on the matter. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted October 15, 2019 Share Posted October 15, 2019 When you open the boot door, the panel you need to access is to your right (behind the dickie seat if fitted). Inside there, you should find the plug, if the previous owner hasn't mucked about with it! 1 Quote Link to comment Share on other sites More sharing options...
liams105e Posted October 16, 2019 Author Share Posted October 16, 2019 Thats great, thank you. I'll have a rummage around, and hope its not been messed with. Cheers Quote Link to comment Share on other sites More sharing options...
