Steering Box 300Tdi
Ok then guy's your mission if you choose to accept it? Is........
I am going to remove the steering box on a 300Tdi 90 is there anything i need to know and is it straight forward?
Plus can anybody tell me what Bolt size BH607161L is.......
What size are NY608041L nuts
I think i am right that the BX112201 bolts are M12 x100mm
Also any other nuts or bolts needed for refitting as i hate re-using old parts?
Have ordered new locking washer 600265, new locking tabs 572077 x2
Once the steering box is off i am taking it to get the drop arm removed so i can refit a new QFW000020G...... Found a place local ie in Derby using Land Rover tools only charging me £15 so well happy especially as i only live the other side of the M1
Cheers Andy
Thanks guys,
Once the drop arm is removed will get it back home and clean up the splines with a wire brush on the Dremel and wire wool, apply plenty of copper slip before fitting new drop arm! Hopefully to make life a bit easier if I ever have to remove it again in the future?
