roybatty666 0 Posted October 27 Well doing a service on the 300tdi I pulled the pan to reseal it as it had a slight leak, when I crapped my pants after finding this in the pan. No sparkles in oil and 90k mile 1996 engine/disco that pulls like a champion on 35s So after I pulled myself together, holding back the tears of what maybe new engine time and cleaned the bits to see what they could be from I realised they are not metal but hard rubber yay😎. Question is what are they off, seems like maybe the cut off end of a T seal? Square end is a definite end piece of something and about 5,6mm almost Composit hard rubber not squishy. Like I say low miles good strong engine, had the valve cover off and now pan and she seems spot on. Any ideas? Will provide more car prawn pics of the beast on correct guess 🤣  Quote Share this post Link to post Share on other sites
monkie 109 Posted October 27 Wash them in some petrol or brake cleaner as well as the magnet test as Bowie suggests. You need to determine if they are iron, aluminium or none metallic to narrow it down a bit. Quote Share this post Link to post Share on other sites
Bowie69 780 Posted October 27 If non magnetic, I'd suggest piston skirt, but very hard to see. Quote Share this post Link to post Share on other sites
Simon_CSK 34 Posted October 27 He did say hard rubber. So a seal of some kind. Although I can't think what could get through the oil galleries. Most likely something dropped into the sump the last time it was off. Quote Share this post Link to post Share on other sites
Bowie69 780 Posted October 27 Odd, I don't remember reading that earlier. Rocker gasket? Anything like that will go hard when in engine oil. Â Quote Share this post Link to post Share on other sites
elbekko 133 Posted October 28 Can it be part of the rear main seal? Quote Share this post Link to post Share on other sites
monkie 109 Posted October 28 Put on of them on a grinder then you'll see if it's metallic or not Quote Share this post Link to post Share on other sites
Stellaghost 73 Posted October 28 You did say you had a leak on the pan don't suppose it was corroded through and the material is some sort of liquid metal used to repair wild guess regards Stephen Quote Share this post Link to post Share on other sites
Snagger 451 Posted October 28 By the rectangular section and solidity, it has to be part of a T-seal as you suggested.  If you’re not losing oil, I’d leave it as is. Quote Share this post Link to post Share on other sites
