OT- yes again I know!!!!
Guest MJG
Just got a very nice digicam but the movie files it records are in *mov format.
Advice needed as to how I merge several movies recorded in *.mov format into one movie. Needs to be no cost if poss, lowest cost if not..........
tia
google for freeware .mov converter
here's a download that should do what you need [apparently] rad video tools
then once you've converted the files to ".asf, .avi, .m1v, .mp2, .mp2v, .mpe, .mpeg, .mpg, .mpv2, .wm, and .wmv"
windows movie maker — included free with xp
first 'import into collections' the files into movie maker
then add the scenes to your project in order [in case one .mov file is split into several clips, ctrl-A select all then put in the project]
then once you've added all the scenes you want for one file, 'save movie file' — it'll be a .wmv file then, it takes a while for higher quality / longer movies; compression is good, eg 5 minutes at 2.1 Mbps quality compresses to 80MB — there's nothing stopping you from converting it back to .mov afterwards I suppose
here's a listing of 300 possible merging programs for you to browse
HTH
Many thanks for that pretty comprehensive reply.
I do use Wndows MM a lot so I am familiar with the second bit it was the merging of mov files I was struggling with - but not for much longer. :i-m_so_happy:
Many thanks
Guest diesel_jim
I use windows MM sometimes, for, ahem, making one long clip from several shorter ones (you know the type... you only get them in 20second parts.... :rolleyes::ph34r::ph34r: from those websites.... :moglite: )
works really well.
works really well.
Tut, disgraceful :angry:
Must try it some time :ph34r:
Many thanks
MM this needs a bit of further work....... mov files converted to avi using this prog, which seems to be the only option to Win MM users displays a very jittery outcome........
Back to the drawing board and thanks for your reply.....
