Green200tdi Posted November 7, 2019 Share Posted November 7, 2019 Quick question, on the TD5’s and some of the early defenders 90’s / 110’s I’m guessing, the head lights have Dim dip beam, if I fit LED head lights will the dim dip work on the led’s dim the led’s down or would I have to by pass the dim dip relay box thing under the bonnet? Quote Link to comment Share on other sites More sharing options...
mad_pete Posted November 8, 2019 Share Posted November 8, 2019 I thought dim dip had to come out for LEDs. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 8, 2019 Share Posted November 8, 2019 Yes, @western will know, but essentially you remove the dim dip relay from behind the dash. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted November 8, 2019 Share Posted November 8, 2019 You'll need to link 2 of the pins after removing the relay. Quote Link to comment Share on other sites More sharing options...
simonpelly Posted November 8, 2019 Share Posted November 8, 2019 Hi There, Some notes on headlights including dim dip bypass relay. https://pellylandroverdefender.blogspot.com/p/headlights.html Simon... Quote Link to comment Share on other sites More sharing options...
western Posted November 8, 2019 Share Posted November 8, 2019 7 hours ago, Bowie69 said: Yes, @western will know, but essentially you remove the dim dip relay from behind the dash. as your now fully Td5 wired, either 1.remove the pink relay & jumper lead the 2 blue/red wires in relay socket, 2. buy & fit the genuine LR bypass relay which just does the above 3. unplug the resistor under the bonnet IIRC its in right rear corner of engine bay. pretty sure the dim dip won't work with led headlights as the led current draw is a lot less than normal halogen units. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted November 8, 2019 Author Share Posted November 8, 2019 5 hours ago, western said: as your now fully Td5 wired, either 1.remove the pink relay & jumper lead the 2 blue/red wires in relay socket, 2. buy & fit the genuine LR bypass relay which just does the above 3. unplug the resistor under the bonnet IIRC its in right rear corner of engine bay. pretty sure the dim dip won't work with led headlights as the led current draw is a lot less than normal halogen units. That’s the answer I’m looking for as I like the dim dip lights, cheers Ralph,😂 mind you I might try see what happens and report back 👍😂 Quote Link to comment Share on other sites More sharing options...
western Posted November 8, 2019 Share Posted November 8, 2019 Dim dip law was repealed about 2006. So it's no longer required. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted November 9, 2019 Author Share Posted November 9, 2019 Well ladies and gentlemen the results are in now it’s finally stopped raining ☔️ it would seem led head lights on normal Headlights on work as normal we know that but on dim dip the Led head lights as pictured above come on but with one of the outer lights off and are a lot dimmer so there you go now we know 😊 dint know if you can see in the two short videos, 144F77C4-A215-4CE2-999C-983CE729DF3D.MOV 0F245E98-1338-4292-8F80-6D11DAFA0B92.MOV Quote Link to comment Share on other sites More sharing options...
