Sabre Posted November 8, 2019 Share Posted November 8, 2019 How much oil does the LT230 take ? I removed the box, had it overhauled, and wanted to fill it before refitting to the gearbox. Haynes specifies 2.3 liters up to suffix D, and 2.8 from suffix E. I tilted the box slightly forward, started filling, and had oil gushing out the filler hole before I could get 2 liters in. Should it be 1.3 and 1.8 liters respectively ? Also, where do I find the "suffix" on the box ? I found a number FTC 4178 on the casing, and FTC 3178 on the PTO cover Thanks in advance Quote Link to comment Share on other sites More sharing options...
Tanuki Posted November 8, 2019 Share Posted November 8, 2019 The official JLR Book-of-Words for my 90TD5 says the transfer-box takes 2.3 Litres. Which is about what I typically budget for when getting 75W80 GL5 [which also goes into the front/rear diffs] for an all-round oilchange. Quote Link to comment Share on other sites More sharing options...
Sabre Posted November 8, 2019 Author Share Posted November 8, 2019 52 minutes ago, Tanuki said: The official JLR Book-of-Words for my 90TD5 says the transfer-box takes 2.3 Litres. Which is about what I typically budget for when getting 75W80 GL5 [which also goes into the front/rear diffs] for an all-round oilchange. As I said, even with the box tilted forward, I could not get 2 liters in. Very strange Quote Link to comment Share on other sites More sharing options...
ashtrans Posted November 11, 2019 Share Posted November 11, 2019 are you filling it with the sump horizontal ? the output flanges sit much lower in the vehicle, Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted November 12, 2019 Share Posted November 12, 2019 Tanuki, you said you fill yours with 75W80 GL5. Does the transfer box have any "yellow" metal, brass or bronze etc, in it, because I believe that GL5 is potentially damaging to these alloys, and that GL4 is recommended? Or have I got it wrong😕? Mike Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted November 12, 2019 Share Posted November 12, 2019 The bushes in the centre diff are bronze. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted November 12, 2019 Share Posted November 12, 2019 GL4 is safer, but I think that the modern GL5 oils are less damaging than the early versions. Quote Link to comment Share on other sites More sharing options...
Sabre Posted November 12, 2019 Author Share Posted November 12, 2019 21 hours ago, ashtrans said: are you filling it with the sump horizontal ? the output flanges sit much lower in the vehicle, I had a look today, and it looks like you are correct, I have the box slanted towards the left, and that will reduce the capacity. I will do the final check/top-up with the box installed in the car Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 12, 2019 Share Posted November 12, 2019 I always fill up once installed, saves spilling it as you fit it. Mo Quote Link to comment Share on other sites More sharing options...
Tanuki Posted November 12, 2019 Share Posted November 12, 2019 (edited) The GL5 I use [Lodexol FS 75W-90] is fully-synthetic and rated as safe for transmissions with 'yellow metal' components. I think the 'thing' about GL5 not being OK for such gearboxes was from 25 years back when GL5 non-synthetic oils were first introduced and some of them included lots of sulphur/phosphorus compounds [Zinc dialkyldithiophosphates?] The stuff I use doesn't stink like the old high-sulphur "EP" hypoid oils. Edited November 12, 2019 by Tanuki 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted November 15, 2019 Share Posted November 15, 2019 On 11/12/2019 at 4:50 PM, Mo Murphy said: I always fill up once installed, saves spilling it as you fit it. Mo It's lighter, too! Quote Link to comment Share on other sites More sharing options...
