petrolhead63 Posted November 13, 2019 Author Share Posted November 13, 2019 (edited) 44 minutes ago, sierrafery said: read again my post nr 18. the alarm and immobiliser are interdependant if you see what i mean ... so set alarm to " not fitted" or "no alarm" or what ever that setting is named cos i forgot then you are sorted ... just go through all the settings untill the menu end and confirm that you change factory setings before you exit . good luck great thanks, its done. No alarm, no passive immobiliser. Running. Onto the issue. It has lost its remote function on the keys. Cheapest to start with the receiver I guess, especially as Hawkeye communicates with the BCU fine too. Are all the receivers for Disco 2 the same? How much headliner do I need to hang down to get to it? Finally if I plug another receiver in will that restore remote locking if it was the fault even though alarm and immobiliser are now disabled until sorted. Your help has been very much appreciated indeed. Thanks. Edited November 13, 2019 by petrolhead63 Quote Link to comment Share on other sites More sharing options...
sierrafery Posted November 13, 2019 Share Posted November 13, 2019 The receivers are two kind based on frequency. for UK you need 433mhz regardless of superseded part numbers but better buy new to be sure . better read all this thread Quote Link to comment Share on other sites More sharing options...
