Green200tdi Posted November 10, 2019 Share Posted November 10, 2019 I don’t know if I’m right here but would the td5 engine coolant temp sensor have a live and earth? Would explain my live at engine with the td5 loom I have put in the 1886 110 with 200 tdi note 2 connectors in td5 sender only 1 on my 200 tdi sender Quote Link to comment Share on other sites More sharing options...
western Posted November 10, 2019 Share Posted November 10, 2019 Earth would be through engine, 1 terminal is 12v power feed & other is the temp signal back to the ECU so the it knows the engine temp & along with other sensors tells the ECU what is good or bad. just run the correct colour code wire from the existing temp sender direct to the temp gauge, you don't need the td5 temp sender. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted November 10, 2019 Share Posted November 10, 2019 TD5 coolant-temperature-sensor feeds to the ECU, not the gauge. The coolant-temperature-sensor is used (along with the fuel-temperature sensor on the pressure-regulator, and the intake-air-temperature sensor in the air-filter-casing) to let the TD5 ECU make decisions on fuelling, EGR-volume, boost-limit, glowplug-energisation etc. As a bit of a sideline the ECU sends a composite-of-various-sensors signal to the dashboard temperature-gauge. Your 'clockwork' engine doesn't need these signals - so single-wire your existing sensor back to an old-style 200/300TDI gauge and it should work. 1 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted November 10, 2019 Author Share Posted November 10, 2019 Now I know why 😂 thanks 👍 I did bridge the wires at the ecu plug and gauge did go to hot when I earthed it out, as I have no ecu tried wiring it in via think was green yellow today at the gauge earth out went to hot so put on temp sender took for a drive to get up to temp but broke down spent the next two hours waiting for the AA🙄 1 Quote Link to comment Share on other sites More sharing options...
western Posted November 10, 2019 Share Posted November 10, 2019 whats gone pop now ?? Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 11, 2019 Share Posted November 11, 2019 11 hours ago, Green200tdi said: took for a drive to get up to temp but broke down spent the next two hours waiting for the AA Ha, gutted 😣 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted November 11, 2019 Author Share Posted November 11, 2019 The bloody wire to the stop solenoid fell off so I’ve bent it up now so won’t come off again plus new spade connector, guess I loosened it when trying to sort thu wires 🙄 1 Quote Link to comment Share on other sites More sharing options...
