frazzyb Posted November 10, 2019 Share Posted November 10, 2019 recently bought a landrover discovery (td5) 1999 all serviced up and ready to go, but when i put the flasher relays in the fuse box located under the steering wheel. even if the engine is turned on or off the hazards come on. there is literraly no control from the button or from the stalk. the only way to turn them off was by talking the relays out. all fuses checked had all the plugs behind the passenger split and checked for corrosion, and that have any sort of corrosion I've cut and joined round the plug. any help at all will be appreciated Quote Link to comment Share on other sites More sharing options...
