Aitch69 Posted November 11, 2019 Share Posted November 11, 2019 (edited) Hi I have a 2005 freelander 1 automatic , I have a issue when selecting “D” I have a yellow light (HDC) that comes up on the dash , I can drive the car but I get 4 come up on the dash and then It changes to a F. If I m really carful when selecting “D” I can prevent the yellow light (HDC) coming on but the slightest movement of the gear shift puts the light on ? Edited November 11, 2019 by Aitch69 Miss spelling Quote Link to comment Share on other sites More sharing options...
digiboy Posted November 12, 2019 Share Posted November 12, 2019 I have the same problem with my 2005 TD4 auto. Flashing F4 on the display is a generic error. I bet it happens after a short run and you stop and restart it? I also bet if you start it in N it won't do it and if you flip the connector off the LHS from that controls the Sport mode it will never do it! I've tried a lot of things including a diagnostic test. I've: Replaced the whole gear selector, replaced the gearbox ECU, replaced the Inhibitor switch, done voltage and continuity checks on the two barrel connectors (they are not damaged or corroded), done continuity checks on the wiring to the Sport mode connector. Basically, the ECU things Sport mode is engaged and you are trying to engage hill descent. So it throws up the error light. It does not go into limp mode and nothing else happens. All I do now is start it the Neutral. I've driven almost 10k miles like it. But I'd still like to know what the hell it is!! 1 Quote Link to comment Share on other sites More sharing options...
Aitch69 Posted February 18, 2021 Author Share Posted February 18, 2021 Sorry you said the LHS what and where is that ? Please Quote Link to comment Share on other sites More sharing options...
digiboy Posted February 21, 2021 Share Posted February 21, 2021 Left Hand Side! See the photo. Quote Link to comment Share on other sites More sharing options...
Hussein Posted January 29 Share Posted January 29 I have the same problem. The DHC light appears when I put the handle on D If you are able to solve the problem, I hope you can help me, thank you very much Quote Link to comment Share on other sites More sharing options...
