Arjan Posted November 12, 2019 Share Posted November 12, 2019 As per title... I need for 2 vehicles a snorkel bent in a few directions. Standard ones will nor fit as they have cages and I'd like to have basically a pipe to take the standard mushroom top and go down into the engine bay where a short piece of rubber hose will connect it, if need be, to the airfilter. Want to stay away from welding pre made bents if possible. Suggestions anyone ? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted November 12, 2019 Share Posted November 12, 2019 Hi Arjan If you don't have access to some pipe benders you could fill pipe with silver sand plug and use heat to get your bends sand will stop pipe deforming failing that any local garage that has the ability to manufacture exhausts may be able to form some large bore pipe for you I have tube benders but way to far away regards Stephen Quote Link to comment Share on other sites More sharing options...
steve b Posted November 12, 2019 Share Posted November 12, 2019 I'd start with a performance exhaust building company , they are the sort of outfit that will have a mandrel bender and dies for thin wall large bore tube . A TIG welded stainless one with pre-made bends in 316 would look nice , hand railing suppliers could be somewhere to search . ...Stellaghost beat me to it cheers Steve b Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 12, 2019 Share Posted November 12, 2019 Are you aware of the PP Cages snorkels? CNC mandrel bent tube, they do various versions. Quote Link to comment Share on other sites More sharing options...
Arjan Posted November 12, 2019 Author Share Posted November 12, 2019 thanks ! local fabrication is not an option - that is here in France a serious issue.. I'll give the various people a call and see what they can do. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 12, 2019 Share Posted November 12, 2019 Fits with or without a cage: https://www.southdown4x4.co.uk/Southdown Defender 200 Tdi Snorkel.htm Few different versions. Quote Link to comment Share on other sites More sharing options...
Team Idris Posted November 12, 2019 Share Posted November 12, 2019 I use strait tube and silicon bends. However, there are bends available in aluminium that are a reasonable price. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted November 13, 2019 Share Posted November 13, 2019 If you can draw it, and work out the angles then Tom @ tube-bender would probably be able to make it and send it to you. He did some roll cage bits for me a while back. Tube Bender Quote Link to comment Share on other sites More sharing options...
Arjan Posted November 13, 2019 Author Share Posted November 13, 2019 Thanks you all ! Have a lot of homework... 1 Quote Link to comment Share on other sites More sharing options...
