nick beale Posted November 15, 2019 Share Posted November 15, 2019 hi can any one help.i have a p38 and its gone mental abs light on tc light on and saying fuses are blown but all ok how can i rest it? Quote Link to comment Share on other sites More sharing options...
steve b Posted November 16, 2019 Share Posted November 16, 2019 Hi Nick and welcome to the forum I'm by no means an expert on the P38 , but it sounds like you may have BeCM issues ? Have you got or had a heater matrix leak as the coolant will track through the carpet to the BeCM under the front seat and they don't like being damp . Hopefully someone with a bit more detail knowledge will come along , @elbekko has a P38 as do some others here . cheers Steve b Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 16, 2019 Share Posted November 16, 2019 If anyone's an expert on soggy BECM's it's @elbekko Quote Link to comment Share on other sites More sharing options...
steve b Posted November 16, 2019 Share Posted November 16, 2019 ....well I didn't want to mention it , but you are right Steve Quote Link to comment Share on other sites More sharing options...
Snagger Posted November 16, 2019 Share Posted November 16, 2019 21 hours ago, nick beale said: hi can any one help.i have a p38 and its gone mental abs light on tc light on and saying fuses are blown but all ok how can i rest it? Are the fuse box contacts clean? They may be dirty or corroded and blocking the current. Have you tried a replacement fuse, too? Sometimes they can blow in a way that they still look ok. Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted November 17, 2019 Share Posted November 17, 2019 You can reset the system by disconnecting the battery and holding the two unconnected leads together for 30 seconds, Reconnect and the system should have reset Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 19, 2019 Share Posted November 19, 2019 On 11/16/2019 at 2:10 PM, FridgeFreezer said: If anyone's an expert on soggy BECM's it's @elbekko 'tis true. I spent a week with the BeCM opened up, a can of contact cleaner and a paintbrush, cleaning it while watching TV Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted November 19, 2019 Share Posted November 19, 2019 2 hours ago, elbekko said: 'tis true. I spent a week with the BeCM opened up, a can of contact cleaner and a paintbrush, cleaning it while watching TV Did you mange to revive the BeCM? 1 Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 19, 2019 Share Posted November 19, 2019 Yup, it's still going strong. Some things even started working again after that, like the mirror dip... Quote Link to comment Share on other sites More sharing options...
Escape Posted November 20, 2019 Share Posted November 20, 2019 @nick beale can you be a bit more specific? Which fuses are blown according to the BECM? And what year is your car? That will help us guide you to possible points of failure. If it's just the ABS/TC that's throwing an error, you can still use the car, you might even have ABS on some wheels, depending on the fault. But if it's a fuse for the brake assist pump, you'd better not drive it as you'll only have front brakes and no assist. Filip Quote Link to comment Share on other sites More sharing options...
Blanco Posted November 20, 2019 Share Posted November 20, 2019 On 11/19/2019 at 2:21 PM, elbekko said: Some things even started working again after that, like the mirror dip... Interesting you mention that, my mirror dip usually goes the wrong way (ie it goes up ..... ) but not all the time, I always assumed it was something to do with the fact that the 2nd hand unit I fitted only had 12 wires instead of 14, but now I wonder if the becm might be damp??? Not that I'll be tempted to open it up unless I have to! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 20, 2019 Share Posted November 20, 2019 If you have a moist BECM, after drying and giving a good scrub with isopropyl alcohol it's worth coating the PCB with conformal coating - RS, Farnell etc. sell it in spray cans for a few quid. Here's an example: https://uk.rs-online.com/web/p/conformal-coatings/0494714/ Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted November 20, 2019 Share Posted November 20, 2019 19 minutes ago, Blanco said: Interesting you mention that, my mirror dip usually goes the wrong way (ie it goes up ..... )... I had to study this point in response to a mailing list query, where the enquirer wanted the door mirror to lift when reversing into his driveway. Reading the drivers handbook closely, when you set this up, you engage reverse then set the required position of the mirror, so the choice of lift or drop is down to the user. Thus there is no 'wrong' way. Regards Quote Link to comment Share on other sites More sharing options...
Blanco Posted November 20, 2019 Share Posted November 20, 2019 2 hours ago, David Sparkes said: so the choice of lift or drop is down to the user. I went through the handbook once and found how to turn it off, but it didn't last past a flat battery, I'll have to drag it out again and have another shufty, thanks. Not sure why it sometimes goes the other way though. 2 hours ago, FridgeFreezer said: after drying and giving a good scrub with isopropyl alcohol it's worth coating the PCB with conformal coating Thanks FF, .... it is great to know what we should do ..... just dealing with essentials at the moment but as soon as normal cashflow is resumed I will invest in a couple of cans and perhaps even indulge in some preventative maintenance Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 20, 2019 Share Posted November 20, 2019 23 minutes ago, Blanco said: Thanks FF, .... it is great to know what we should do ..... just dealing with essentials at the moment but as soon as normal cashflow is resumed I will invest in a couple of cans and perhaps even indulge in some preventative maintenance You shouldn't need a couple of cans unless you're coating the whole car! One can will do numerous boards. For IPA a stiff artists' brush or cheap toothbrush should get any crud gone - then check all the solder joints for corrosion / cracks before coating. Quote Link to comment Share on other sites More sharing options...
Blanco Posted November 20, 2019 Share Posted November 20, 2019 2 hours ago, FridgeFreezer said: You shouldn't need a couple of cans I assumed the Iso-whatsit alcopop came in a can as well, ..... I meant one of each Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 21, 2019 Share Posted November 21, 2019 16 hours ago, FridgeFreezer said: If you have a moist BECM, after drying and giving a good scrub with isopropyl alcohol it's worth coating the PCB with conformal coating - RS, Farnell etc. sell it in spray cans for a few quid. Here's an example: https://uk.rs-online.com/web/p/conformal-coatings/0494714/ Yeah, I've had a can of conformal coating sitting around waiting to be applied since then Quote Link to comment Share on other sites More sharing options...
