Intermittent clutch after replacement - O/D Rebuild (Combined Thread)
Incorrect spring pressure wouldn't create an intermittent fault; you'd get a consistent amount of slipping all the time when disengaged.
Looking up how it operates: when engaged, the solenoid blocks a return from the pump allowing it to build pressure against the relief valve and the pistons to overcome the spring pressure. This means the return path is open when disengaged, with the pump simply circulating oil. Sensible as its not then using power. Western has obviously had it apart and scrupulously cleaned it, but is the return accessible enough that you can verify its not got a piece of casting flash or something stupid like that isn't partially blocking it and acting like the solenoid? Significant facts here: problem occurs when cold: Thick oil finds it harder to pass said blockage. Problem occurs after coming to a stop when warm: The pump - being driven by the gearbox output - doesn't produce any flow when the vehicle is stopped. This allows this theoretical piece of blockage to move from a position where it was previously passing oil to one where it doesn't, until such a point as flow drops off again or overcomes it. Either that or somehow the solenoid is getting actuated when it shouldn't?
How about the spring seats?  They could be a little worn.  Something is preventing proper spring pressure clamping the brake pack.  Intermittent behaviour could be caused by thermal expansion of the mechanical parts or casing, or the thermal effect on the brake pack (fluid temperature, pack layer friction, expansion or contraction of plates).
The springs sit directly on the cone clutch bearing carrier & act against the rear housing, see reb's strip down photos earlier, there are no separate spring seats.
The solenoid is directly switched from the gearknob switch, this is the 12v feed to energise it, the earth goes from solenoid terminal to one of the OD attachment bolts.
23 hours ago, landroversforever said:
If you’re considering the possibility of cracks in the housing/bores, it’s probably worth having or doing some NDT like dye-pen testing. I assume it something you’d have access to at work Ralph?
For those not in the know, with dye-pen (dye penetrant) you douse it in a dye which can wick into tiny imperfections. The object is then cleaned and sprayed with a developer which is like a chalky substance and you can then see the dye soak out of any imperfections.
This is where my brain was going when I mentioned the cracked casing above, but confess I didn't know a process that could work with aluminium.
It has to be this, or as above, the solenoid leaking a little, pushing the cone just enough to push back the springs a little.
I have to wonder it it could be made to work with a lever, and no pump at all!
Interesting thoughts. I cant remember how accessible the oil passages are. Swapping the rear housing would solve all of this as the issue that Ralph had was clearly not caused by a problem there.
Ralph, if you get chance, could you post a pic of the relief valve setup please? This is the only thing I havent taken apart on mine so curious as to how it goes together!
I cant think how as you would have to put a central fork in to move the clutch, but both sides of the clutch have a function so the fork would get in the way. You would also have to seal the pivot as the whole thing is bathed in oil.
54 minutes ago, landroversforever said:
Would it be worth rigging another temporary way of switching the solenoid? That would rule out any possible issues in the wiring to the switch on the gearstick.
Simply detaching wires would prove this.. It's slipping when not engaged, so not powered. If no power applied and it still slips it proves it not the wiring.
The thinking of pressure building up and starting to move the cone clutch is one I considered too, hence replacing the solenoid originally.
Good resources:
https://www.buckeyetriumphs.org/gearbox
https://www.landypedia.de/index.php/Überholung_eines_GKN_Overdrives
Its had two different sets of wiring tried on it at least so I don't think it can be this.
I'll remove the 12v feed fuse & see what happens tomorrow on the way to work, that way I know no loose wiring will be flapping about underneath, it'll give the same affect as disconnecting the 12v feed on solenoid. the wiring in my 110 is fine it worked fine with the original OD fitted.
Ralph, if you get chance, could you post a pic of the relief valve setup please? This is the only thing I haven't taken apart on mine so curious as to how it goes together!
borrowed from this website https://www.landypedia.de/index.php/Überholung_eines_GKN_Overdrives
it has 2 concentric coil springs
this valve in both my  OD rear cases is spotless clean & no apparent damage
From left to right: Valve body, control piston, shims, springs, spring cup, front hole cover. Above is the cylinder of the dashpotDashpot.jpg
Fuse removed & solenoid does NOT operate when ign is on & gear knob switch is switched to on.
At work now, even with the solenoid empower disabled OD slipped 5 times on the way to work, worst occurrence as pulling away from a give way line on a roundabout, took a reduction of revs to almost idle to get OD to grip & give some drive. So solly can be discounted as the cause.
Did you have the (main) clutch engaged when letting the revs drop to idle at the give way? If so, it feeds into my theory about an intermittent blockage needing oil flow to drop to reset. If that is the case, it's either a foreign object (casting flash or core remnant, perhaps) or the solenoid is somehow randomly  dropping in against its return spring when oil flow drops to zero as you come to a stop, but I think the latter unlikely.
Only a little just enough to keep the main gearbox engaged, but I don't believe that is the problem as the OD is meant to be engaged & disengaged under power without using the vehicles clutch.
I will check the original rear case before fitting it with new piston seals & new filter to see if the oil ways are clear.
Edited by western
That is right.  That’s the benefit of epicyclic gears with clutch pack selectors - everything is already meshed, so you can have instant changes without removing torque.  It’s how automatic transmissions work, and this is essentially a two speed auto.
  • Like 1
It's a clever design. I was more wondering about what the oil pump may or may not have been doing while you were stopping/failing to start/finally getting going. Interested to see how it behaves with the other rear casing. Fingers crossed!
the parts pack from overdrive repairs arrived today, so I now have a nice new clean filter for the rear section & seals for the pistons, solenoid & other items
the 3 smallest O ring seals are for the solenoid internal rod & next 2 bigger seal are for the solenoid outer rod.
Piston seals x 2 below pen nib
Solenoid seals x 2 below pen nib
nice shiney new clean filter & gasket
  • Like 1
not much progress so far, but I have made sure all the fluid galleries in my original rear case are clear of dirt & any other items that could cause a restriction, so I'll be building it up tomorrow ready to swap over & hopefully all this work/expense will make this OD work properly.
I will take some photo's as it progresses to 'ready to fit' state
I have found that the seal kit shown above contains the seals for the relief valve, fluid pump & solenoid seals.
  • Like 1
This afternoon & evening has mainly be taken up by fitting the new seals to the relief valve, fluid pump & replaced the seals on my newer spare solenoid & the new circular filter in to my original overdrives rear casing,  the flat filter in sump & the magnetic strip cleaned, I also bought a new brake cone as well I know the existing cone was new but I didn't want to be taking the OD off again to replace the cone,
some photo's below
so & after fitting this lot to the 110 & doing a 18 mile test drive on local town roads, a run down to Hayle & back home along the A30, all seems to be OK,
I'll check the fluid level in the morning, hopefully the OD should work fine now. :D
Relief valve with new seals fitted & old seals above their respective locations
relief valve sleeve in rear case of overdrive, the cut out & fluid drilling must be inline
relief valve pin located in the rear case.
the 2 springs located on the relief valve pin.
relief valve outer sleeve located over the 2 springs & pin. then the end cap is screwed down tight.
circular filter location.
new circular main fliter,gasket & end cap with new seal fitted.
new filter & gasket in place, then end cap is screwed down tight.
  • Like 1
OD fluid pump parts, old seals above their respective locations & new seals fitted.
housing fitted ready for the concentric offset drive from main shaft.
bottom part of pump assembly in place, the fluid way must match the rear case drilling
pump relief valve seat in place, a ball bearing sits in the centre, it's spring in the end cap.
ball bearing valve in place
fluid pump end cap & spring, this was fitted & screwed down tight.
all 3 caps tight in place, ready for the swap over to become the operational overdrive.
  • Like 1
