Bigj66
110 3 door Side Steps
Does anyone know of a supplier of side steps for a TD5 110 3 door van?
There seems to be lots available for the station wagon but finding some for the 3 door with the different body mounting points is proving to be elusive.
Are the fold away steps the only option for this model?
Share this post
Link to post
My work vehicle is a 16 plate 110 van with side steps, no idea of make as they were fitted from new,  double tube type, but they are / were available if it’s any help.
Share this post
Link to post
Cheers, I’ll keep searching. I think the issue is that there is no rear floor support to attach the rear fixing to but as with yours, maybe someone has found a way around that.
Share this post
Link to post
I’ll take some photos on Monday if you like. I’ve never looked under it in the three years I’ve had it!
Share this post
Link to post
I bought some fire and ice ones and when I came to fit them there was nothing except the wheel arch space at the rear so I had to send them back. Even the supplier was a bit puzzled.
This is a view of the underside.
Share this post
Link to post
Mine has side lockers in the rear tub- The steps are bolted to the floor of the locker and also to the outrigger. The brackets look fabricated by Roger Young (main dealer who did the fit out on it)
Share this post
Link to post
3 hours ago, ianmayco68 said:
Cheers.
 I took a look at the fitting instructions on their website but will need to check to see if I have the same underfloor structure as they show in their photo.
https://www.sidesteps.co.uk/wp-content/uploads/2019/04/defender-110-steps-fitting.pdf
Failing that I’ll just go for the single steps.
Share this post
Link to post
