Simon_CSK Posted November 25, 2019 Share Posted November 25, 2019 The heater return pipe on my Range Rover (P38 4.6) is leaking at the inlet manifold. It there a gasket that fits on this or is it an o ring? Basically how does it seal? Quote Link to comment Share on other sites More sharing options...
Escape Posted December 4, 2019 Share Posted December 4, 2019 I think you mean the heater supply pipe, the return pipe goes to the thermosthat (with a T to the expansion tank), not to the inlet manifold. All hoses are fitted with clamps, nothing more. There are O-rings between the pipes and the heater core in the interior, those are known to leak and hard to reach... Filip Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 4, 2019 Share Posted December 4, 2019 22 minutes ago, Escape said: I think you mean the heater supply pipe, the return pipe goes to the thermosthat (with a T to the expansion tank), not to the inlet manifold. All hoses are fitted with clamps, nothing more. There are O-rings between the pipes and the heater core in the interior, those are known to leak and hard to reach... Filip That's not quite right, one of the pipes fits into the manifold with an O-ring. Quote Link to comment Share on other sites More sharing options...
Escape Posted December 4, 2019 Share Posted December 4, 2019 Aah yes I forgot the little stub is separate from the manifold... I was just thinking about the pipes/hoses. Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted December 4, 2019 Author Share Posted December 4, 2019 4 hours ago, elbekko said: That's not quite right, one of the pipes fits into the manifold with an O-ring. That is the littler bu**er I am talking about. Have fitted an o ring and it seems to be holding but am wondering what the correct o ring is. Quote Link to comment Share on other sites More sharing options...
=jon= Posted December 4, 2019 Share Posted December 4, 2019 https://rimmerbros.com/Item--i-ERR6434 Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted December 5, 2019 Author Share Posted December 5, 2019 18 hours ago, =jon= said: https://rimmerbros.com/Item--i-ERR6434 Thanks Quote Link to comment Share on other sites More sharing options...
