steve b Posted December 1, 2019 Share Posted December 1, 2019 My 12v bleed pump has given up after 25 years of service and I'm not sure I want to spend that much (~£700 + ) , a friend suggested Sealey pressure units , I see VS0205 is a LRM star buy . Anyone got one and what do you think ? Or what do you use ? cheers Steve b Quote Link to comment Share on other sites More sharing options...
Blanco Posted December 1, 2019 Share Posted December 1, 2019 I use Gunsons Ezibleed which is very similar, works really well, you don't need much pressure for most systems about 10psi is plenty. Cheap and cheerful, I have a larger one, but cleaning it out is a pain, so generally just use the Ezibleed. Quote Link to comment Share on other sites More sharing options...
western Posted December 1, 2019 Share Posted December 1, 2019 I just use one similar to this https://www.halfords.com/workshop-tools/tools/hand-tools/europat-vizibleed-brake-and-clutch-bleeding-kit Quote Link to comment Share on other sites More sharing options...
steve b Posted December 1, 2019 Author Share Posted December 1, 2019 The eezi-bleed is a good bit of kit , what I like about the pressure bleed with reservoir is I can attach it and lift the 4 post and do it all in one go , within the limit of the capacity of the reservoir. 500ml goes a fair way doing component changes and is probably nearly enough to do a brake fluid change. cheers Steve b Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 1, 2019 Share Posted December 1, 2019 Another one for Gunnisons ezibleed had mine for 20 year still going strong regards Stephen Quote Link to comment Share on other sites More sharing options...
L19MUD Posted December 2, 2019 Share Posted December 2, 2019 +1 for the Easibleed although to be honest I quite often just use a bit of rubber hose with a bolt screwed in the end to cap it and a slit about 15mm long just above the bolt. It acts as a valve and allows the fluid out but not the air back in. I then just position a container in the right place to catch it. Clutch slave cylinders on Defenders are a pain as you only get 3 pumps of the pedal before you have to top up the reservoir (which is a pain if it is in the air on the ramp) Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 2, 2019 Share Posted December 2, 2019 I've used the Motive pressure bleeder for year. Very simple and easy. Screw on, pump up and bleed. Works for the clutch as well. https://www.motiveproducts.com/collections/import-power-bleeder-kits/products/0100-european-bleeder Quote Link to comment Share on other sites More sharing options...
steve b Posted December 2, 2019 Author Share Posted December 2, 2019 Looking at your link Red90 , I'm now wondering if a pump plant sprayer would do , I've already got all the caps from the old 12v pump . Might have to have a rummage in the garden shed and see what I have . Nice unit though thanks for pointing it out , clutch bleeding is part of the motivation for getting a pressurised fluid bottle . cheers Steve b Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 2, 2019 Share Posted December 2, 2019 The problem with some home made setups like that is they have seals or materials that are not compatible with brake fluid. So, it might work, but you might also end up with a seized pump over time. Here is a more local one: https://www.amazon.co.uk/Sealey-VS820-Clutch-Bleeding-System/dp/B000ROARTI/ref=pd_sbs_263_t_0/259-4456809-5247053?_encoding=UTF8&pd_rd_i=B000ROARTI&pd_rd_r=4336776d-b865-43cf-8f06-df71fc098d49&pd_rd_w=FP8UX&pd_rd_wg=czHmp&pf_rd_p=e44592b5-e56d-44c2-a4f9-dbdc09b29395&pf_rd_r=840SX44AGRC1ARTVCP9R&psc=1&refRID=840SX44AGRC1ARTVCP9R Quote Link to comment Share on other sites More sharing options...
steve b Posted December 2, 2019 Author Share Posted December 2, 2019 Agreed , I'll see what my local Sealey Agent can do on that model too cheers Steve b Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted December 4, 2019 Share Posted December 4, 2019 I have the gunsons eezibleed too, cheap but always worked so long as you remember not to run out of fluid. Apart from a kit car I was restoring for a friend. I tried and tried to get the back to bleed and it wouldn't, lots of head scratching and swearing until I realised the builder had put the calipers on upside down to suite the handbrake cable. To get them to bleed I had to take them off, turn them over, wedge a lump of metal between the pads then bleed them Quote Link to comment Share on other sites More sharing options...
