FridgeFreezer Posted December 11, 2019 Share Posted December 11, 2019 I'm surprised you couldn't manage over 45mph, unless someone's fitted a 1-ton transfer box to your Series the gearing shouldn't be THAT low Anyway, sound like you're happy with the result. Quote Link to comment Share on other sites More sharing options...
lo-fi Posted December 11, 2019 Share Posted December 11, 2019 No, quite. Even my 2.25 would plod along at 60. 1 Quote Link to comment Share on other sites More sharing options...
youngengineer Posted December 11, 2019 Author Share Posted December 11, 2019 (edited) 40 minutes ago, lo-fi said: No, quite. Even my 2.25 would plod along at 60. 60?! Thing can't be "plodding along" must be screaming.. is that a true 60 or what's indicated on that thing that flaps around with a mind of its own? If it's petrol I could understand as more rpm would be available and with less noise. I'm running 45mph at 2700ish rpm which is just about bearable and inline with Ashcroft's ratio calculator so definatly not making this up! I use GPS to calculate speed which shows me true speed and have a tachometer fitted which I synchronized to the crank with a laser rpm metering thingy. Would assume it's accurate as it corresponds almost perfectly with Ashcrofts calculator. Edited December 11, 2019 by youngengineer Quote Link to comment Share on other sites More sharing options...
lo-fi Posted December 11, 2019 Share Posted December 11, 2019 Granted it was doing a few revs, but well within the range of a tdi. The little Perkins turbo D I hated so much ran similarly with the same box, though I think by that stage I'd fitted an overdrive. How did you get on checking the meshing of the 3.54 diff and pinion once in the series axle case? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 11, 2019 Share Posted December 11, 2019 My 88" would do 60mph with a 2.25 petrol - a Tdi would easily achieve it but the problem would be noise. Especially if you don't have much soundproofing. The Tdi will safely rev up to around 3,500-3,800 RPM in theory but in my experience anything over 2,500 RPM sounds horrendous. The result being that it sounds a lot worse than it is. Quote Link to comment Share on other sites More sharing options...
youngengineer Posted December 11, 2019 Author Share Posted December 11, 2019 (edited) 1 hour ago, lo-fi said: Granted it was doing a few revs, but well within the range of a tdi. The little Perkins turbo D I hated so much ran similarly with the same box, though I think by that stage I'd fitted an overdrive. How did you get on checking the meshing of the 3.54 diff and pinion once in the series axle case? I'm afraid ive not had time to check the meshing. I was rushed for time last night as I wasted hours extracting a halfshaft that went in too deep. I figured out after 2 hours that it could be knocked out from the other side with a bit of pvc tubing... I used the existing crush washer and and tightened the nut to 130NM which is the spec I found from Sailsbury. I tightened the bearing carrier/saddle? bolts to 90NM which again was a spec I found online. No idea if its been done right but there arnt any nasty noises. I suppose time will tell. The complete sailsbury axle cost me £20 so I suppose it would not be a big loss if it goes out prematurely although not ideal. Edited December 11, 2019 by youngengineer Quote Link to comment Share on other sites More sharing options...
youngengineer Posted December 11, 2019 Author Share Posted December 11, 2019 (edited) 46 minutes ago, Retroanaconda said: My 88" would do 60mph with a 2.25 petrol - a Tdi would easily achieve it but the problem would be noise. Especially if you don't have much soundproofing. The Tdi will safely rev up to around 3,500-3,800 RPM in theory but in my experience anything over 2,500 RPM sounds horrendous. The result being that it sounds a lot worse than it is. I agree. 2200 to 2500 sounds ok to me. Anything over 3000 feels horrible. I recently stripped the bulkhead and added around 10-30mm of acoustic foam which has made a huge difference. But it still aint exactly quite. Edited December 11, 2019 by youngengineer 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 11, 2019 Share Posted December 11, 2019 Nice truck, love a 109 pick up. I expect it would be a lot quieter with a proper air box on it as well. 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 11, 2019 Share Posted December 11, 2019 Sweet, it looks even cooler dirty: https://www.brianmicklethwaitsnewblog.com/2019/05/25/dirty-land-rover-in-soho/ ...did you know you can google image search number plates now? I had a feeling I'd seen the truck somewhere before and happened across this. 1 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 11, 2019 Share Posted December 11, 2019 1 hour ago, FridgeFreezer said: ...did you know you can google image search number plates now? Didn't know that! Just searched my 90 and didn't turn anything up, but found my Grandy's range rover. Quote Link to comment Share on other sites More sharing options...
youngengineer Posted December 11, 2019 Author Share Posted December 11, 2019 (edited) 3 hours ago, FridgeFreezer said: Sweet, it looks even cooler dirty: https://www.brianmicklethwaitsnewblog.com/2019/05/25/dirty-land-rover-in-soho/ ...did you know you can google image search number plates now? I had a feeling I'd seen the truck somewhere before and happened across this. Did not know that. I know its become somewhat famous in London now. It was in a rap video in the summer. Interesting they think it was "Sprayed with mud" Its not the first time i've had people question why mud was not round the wheel arches, then I have to explain about narrow axles and wheels being recessed into body etc. Obviously the mud is thrown up onto the body when hitting large pools of water. Im certainly not wasting time throwing buckets of mud onto it! Edited December 11, 2019 by youngengineer 1 Quote Link to comment Share on other sites More sharing options...
youngengineer Posted December 13, 2019 Author Share Posted December 13, 2019 (edited) On another note I now have a 110 axle and a series diff. What would provide the best resale value, a 110 axle fitted with series 4.7 diff. Or breaking up the axle selling half shafts, hubs etc. Weighing it in and sell the series diff seperately.? Any ideas welcome. Edited December 13, 2019 by youngengineer Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted December 13, 2019 Share Posted December 13, 2019 LED headlights on a series. You heathen. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 13, 2019 Share Posted December 13, 2019 33 minutes ago, youngengineer said: On another note I now have a 110 axle and a series diff. What would provide the best resale value, a 110 axle fitted with series 4.7 diff. Or breaking up the axle selling half shafts, hubs etc. Weighing it in and sell the series diff seperately.? Series diff must be worth something, I might even know a guy who'd have it. Not so sure about an old 110 axle Quote Link to comment Share on other sites More sharing options...
Arjan Posted December 13, 2019 Share Posted December 13, 2019 Very Nice !!!! Love the 109" and........ what's wrong with LEDs on a Series..... 😊 1 Quote Link to comment Share on other sites More sharing options...
youngengineer Posted December 13, 2019 Author Share Posted December 13, 2019 1 hour ago, daveturnbull said: LED headlights on a series. You heathen. I quite like it. An I'm one of those guys that usually finds all.of that stuff hideous. And guess what, I can now actually see at night. Quote Link to comment Share on other sites More sharing options...
youngengineer Posted December 13, 2019 Author Share Posted December 13, 2019 1 hour ago, FridgeFreezer said: Series diff must be worth something, I might even know a guy who'd have it. Not so sure about an old 110 axle Let me know. I may just weigh in the axles then. Half shaftss worth keeping? They are in great condition. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 13, 2019 Share Posted December 13, 2019 2 hours ago, youngengineer said: Let me know. I may just weigh in the axles then. Half shaftss worth keeping? They are in great condition. If they floated past Basingstoke I'd have the whole collection off you... as it stands I probably can't justify fighting my way in & out of London to collect them Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 14, 2019 Share Posted December 14, 2019 I think John maybe right and that you may have a 1-ton transfer box - even a tires 2.25 petrol should manage 60mph (without too much noise), so something was amiss. Likewise, fourth gear is good for low rpm chugging at 30mph, but generally not much else around town, so something odd is going on with your transmission. Yes, I have a Tdi in my 109, as did most of the guys I mentioned who tried 3.54s and didn’t get on with them. Overdrive works so much better, though it still leaves top gearing a little lower than ideal. HRTC sits somewhere between the two, so should be a good compromise for a Tdi or V8, and doesn’t screw up low range like the diff swap does. Quote Link to comment Share on other sites More sharing options...
youngengineer Posted December 14, 2019 Author Share Posted December 14, 2019 (edited) 1 hour ago, Snagger said: I think John maybe right and that you may have a 1-ton transfer box - even a tires 2.25 petrol should manage 60mph (without too much noise), so something was amiss. Likewise, fourth gear is good for low rpm chugging at 30mph, but generally not much else around town, so something odd is going on with your transmission. Yes, I have a Tdi in my 109, as did most of the guys I mentioned who tried 3.54s and didn’t get on with them. Overdrive works so much better, though it still leaves top gearing a little lower than ideal. HRTC sits somewhere between the two, so should be a good compromise for a Tdi or V8, and doesn’t screw up low range like the diff swap does. 1-ton box would give me 3900RPM at 50Mph... I'm not even close to 3000 at 50mph. Petrol I would assume would be much more derivable then a diesel at high revs. Edited December 14, 2019 by youngengineer Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 14, 2019 Share Posted December 14, 2019 I can’t remember the max rpm for petrols, but it’s not much higher than the diesel - hardly surprising as they are fundamentally the same engines. The key difference in driving is the noise and smoothness levels, much better in the petrol engines, so they are more comfortable at high rpm than the diesels. Whatever is going on, with a Tdi and standard transmission, you should be able to do 70mph or more, albeit noisily. With an overdrive, cruising is comfortable at about 60-65 using a Tdi, but mine does 85+ with the roof rack, lights and snorkel, so yours should do more. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 14, 2019 Share Posted December 14, 2019 4000 for petrol's, iirc. Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 14, 2019 Share Posted December 14, 2019 I think the 12J was 4000. Tdi is 4250, but that has greater differences than the 2.25 petrol and diesel versions. Quote Link to comment Share on other sites More sharing options...
youngengineer Posted December 14, 2019 Author Share Posted December 14, 2019 (edited) 1 hour ago, Snagger said: I can’t remember the max rpm for petrols, but it’s not much higher than the diesel - hardly surprising as they are fundamentally the same engines. The key difference in driving is the noise and smoothness levels, much better in the petrol engines, so they are more comfortable at high rpm than the diesels. Whatever is going on, with a Tdi and standard transmission, you should be able to do 70mph or more, albeit noisily. With an overdrive, cruising is comfortable at about 60-65 using a Tdi, but mine does 85+ with the roof rack, lights and snorkel, so yours should do more. 70mph at redline yes. But who drives around at redline? Again, how are you calculating your speed? My friend would constantly boast about doing 70mph in his series 2A fitted with a 200tdi until he blew it to pieces driving up from leeds to Scotland. Again his speedo would show 70mph but in reality it was not close to real speed. Edited December 14, 2019 by youngengineer Quote Link to comment Share on other sites More sharing options...
youngengineer Posted December 14, 2019 Author Share Posted December 14, 2019 (edited) 21 hours ago, FridgeFreezer said: If they floated past Basingstoke I'd have the whole collection off you... as it stands I probably can't justify fighting my way in & out of London to collect them Well I could deliver it. I sometimes i make my way to plymouth. I would hate to scrap a perfectly good axle. I don't suppose you might have a 3.54 diff to fit my front axle? That would be very handy. I believe its a 10 spline. Edited December 14, 2019 by youngengineer Quote Link to comment Share on other sites More sharing options...
