christer Posted December 2, 2019 Share Posted December 2, 2019 Hi. Regarding Discovery II 2002. Does anyone know if the bottom pipe on the valve block, for the rear , goes to the rearmost connector on the rear hydraulic cylinder. I checked it a few months ago, but need reassurance. Note to self: WRITE stuff down.... Thanks Christer Sweden Quote Link to comment Share on other sites More sharing options...
sierrafery Posted December 2, 2019 Share Posted December 2, 2019 IIRC the bottom rear from the block goes into the port on the actuator which is close to the rubber gaiter, the pipe which is bent twice to 90 degrees there Quote Link to comment Share on other sites More sharing options...
