BogMonster Posted December 8, 2019 Share Posted December 8, 2019 Driving the two vehicles (2015 Puma and 2006 Tdi) the other day in the rain, I realised how much the performance of the old one's washer system has deteriorated (unless the Puma has an upgraded pump - but it's miles better at covering the screen). I don't want to spend a million quid on an Optimill system but what options are out there that are worthwhile and sensibly priced? I have wondered about simply drilling the jets out slightly to get better water flow (I think they are probably scaled up a bit inside - either that or the original washer pump is getting tired). Thoughts please? Has anybody tried running a very small drill through the existing jets? Quote Link to comment Share on other sites More sharing options...
western Posted December 8, 2019 Share Posted December 8, 2019 I fitted 2 front screen washer jets to the unused holes on bulkhead & covered the original location hole, the standard pump delivers plenty of screen wash, maybe your pump & tubes need a clean out or replacing. other option is Nige's washer jets on the wiper arms. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted December 8, 2019 Share Posted December 8, 2019 What about disconnecting the pipe from the pump first to see if you can get an indication of the pressure and flow rate it's putting out first? If that seems reasonable then it might be your pipes need cleaning out - maybe an airline up them might help blow stuff out (might want to do backwards). I've been contemplating adapting headlight washer pumps for mine, not got around to it yet though. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 8, 2019 Share Posted December 8, 2019 I've got discovery 1 headlight washer pump and jets fitted to the ibex (and the tomcat before that). The pump fits one of the under wing type tanks (might be a military one though) it's plumbed with something like 8mm ID hose. There's a non return valve at the split (also discovery 1 item). I then cut the jets down the fit on the bonnet. they are quite powerful but the tank does empty quickly if your not careful. Mike 1 Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 8, 2019 Share Posted December 8, 2019 SO I fitted two double outlet jets to my bonnet. At the same time fitted an extension pipe that wrapped round my heater pipe to warm the fluid. I removed the rear washer pipe and ysed that to feed the jets on my wiper arms. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 8, 2019 Share Posted December 8, 2019 I'll second the headlamp washer pump mod, it's about twice the size of a normal one and hoofs out a lot more water. It does pop into the standard hole on a few screenwash tanks, or you can drill the hole out with a step drill. Quote Link to comment Share on other sites More sharing options...
hurbie Posted December 8, 2019 Share Posted December 8, 2019 also have a look on the routing of the washer tube , it may get caught behind the dash (at least on a LHD vehicle it make's a rather funny bend around som parts of the dash-structure) , downside is you have to remove the top dash panel to get acces. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 8, 2019 Author Share Posted December 8, 2019 6 hours ago, Ed Poore said: What about disconnecting the pipe from the pump first to see if you can get an indication of the pressure and flow rate it's putting out first? If that seems reasonable then it might be your pipes need cleaning out - maybe an airline up them might help blow stuff out (might want to do backwards). I've been contemplating adapting headlight washer pumps for mine, not got around to it yet though. Yes ... doing it to the inside could be messy... I have thought for some time that a Discovery headlight washer pump would be awesome as a screen wash pump, but not looked at the feasibility of it. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 8, 2019 Author Share Posted December 8, 2019 Turned out that the nozzles were just a bit bunged up, a good rummage around with the point of a needle and sorting out the alignment of them seems to have restored a reasonable amount of washiness 💧 2 Quote Link to comment Share on other sites More sharing options...
