ianmayco68 Posted December 9, 2019 Share Posted December 9, 2019 Hi all , the connector in the pic is a bit knackered when I noticed it yesterday it was loose , it connects the main loom to the heater on a 200tdi , so am I safe to replace it with a econoseal connector or is it too high draw ? If so can someone recommend a suitable one please , as I believe you can’t but those connectors and I wouldn’t be able to fit one anyway. Cheers for any advice Ian Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted December 9, 2019 Share Posted December 9, 2019 (edited) Given that the 300Tdi's use an econoseal connector here, I think you'll probably be alright. Oh, and half of that one looks non-standard, which is probably why it doesn't fit properly. Edited December 9, 2019 by daveturnbull Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted December 9, 2019 Share Posted December 9, 2019 Here's the 300Tdi one. https://www.lrworkshop.com/connectors/defender-1996-300tdi/C846 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted December 9, 2019 Author Share Posted December 9, 2019 Cheers Dave , i thought it would but wanted to check before a fire occurred . I never thought to check the 300tdi loom I’ve got lying on the floor from the 90 rebuild , I presumed they would both have the rubber connector. I did wonder about the connectors the one in the heater is original, well it was there when I brought the truck , the other attached to the loom is a new Autosparks loom . Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted December 9, 2019 Share Posted December 9, 2019 The 300tdi got rid of all the rubber bullet connectors for econoseals in 1994 apart from the steering column switchgear. They waited until 1995/6 to go over to econoseals for them for some reason! Quote Link to comment Share on other sites More sharing options...
