How warm ?
Matt2e0fgx
15 minutes ago, Matt2e0fgx said:
Replaced correctly ? What you mean ?
Never took one apart on a d2 so wouldn't know what looks like . One done a o ring or a seal around the thermostat that pushes into housing and a gasket or o ring to seal .
thermostat is best described as being heart shaped, it is mounted to the radiator cowling between the top & bottom hose essentially , 3 hose clips & easy to change,
If you look at the thermostat you'll see there are 2 ports on one side and one on the other. Make sure you get the 2 port side the correct way round.
