Shaun3642 Posted December 18, 2019 Share Posted December 18, 2019 Hi guys I'm busy building in a Rover v8 into a series 3. I have a few questions regarding the positioning of the engine. I have almost no space on the passenger side to fit the manifold in between the chassis rail and the engine. Do I need to shift the engine and gearbox over? What manifolds did you use? Thanks Quote Link to comment Share on other sites More sharing options...
lo-fi Posted December 18, 2019 Share Posted December 18, 2019 You need to mod the passenger footwell. There's just not enough room otherwise, regardless of which manifold you choose. Shifting the engine to the right will give you more headaches with oil pump to diff clearance and suchlike. Quote Link to comment Share on other sites More sharing options...
Shaun3642 Posted December 18, 2019 Author Share Posted December 18, 2019 Does anyone possibly have a picture of the passenger side manifold with regards chassis and footwell? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 18, 2019 Share Posted December 18, 2019 As lo-fi says think I took about 50-75mm out of inner section of footwell even that leaves it still slightly awkward for plugs and manifold bolts I also fitted an angled connector to oil pump housing to stop diff hitting it or alternatively a remote oil filter regards Stephen Quote Link to comment Share on other sites More sharing options...
Shaun3642 Posted December 18, 2019 Author Share Posted December 18, 2019 Hi Guys Thanks for the responses. I'm just battling to find the space between the engine and the chassis rail to fit a manifold in unless I lift the engine or move it towards the drivers side. If anyone has maybe a picture, it would be of great help Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 18, 2019 Share Posted December 18, 2019 Here's all the pics I could find of mine in my 109 - the engine is shifted back a fair bit for various reasons; Other side: Overall with exhaust - the tubular headers follow the positioning of the standard manifolds; This shows the passenger side exhaust, engine mount, chassis, bulkhead; Quote Link to comment Share on other sites More sharing options...
lo-fi Posted December 18, 2019 Share Posted December 18, 2019 I used Discovery manifolds on mine, they hug the block quite well and exit at convenient points. Clearance with the chassis rails isn't normally an issue, though... Pics may help? Quote Link to comment Share on other sites More sharing options...
