KEITHB252 Posted December 18, 2019 Share Posted December 18, 2019 Problem with my CD multi changer in my TD4. Radio works fine,change to CD message says "No cd".I eject the case from the machine,put it back in i then goes through loading all 6 cds and then says no cd. Has anyone any ideas please.Thank You. Quote Link to comment Share on other sites More sharing options...
Dorsetfreelander Posted December 18, 2019 Share Posted December 18, 2019 Sounds like the laser has gone "soft" in the CD player and it can't read the TOC (table of contents). This is a common problem with HI Fi systems after a few years and if you are lucky you can strip them down and find a preset to turn up the wick slightly but you are on borrowed time. The only other thing is a lens cleaner CD, give that a go. Quote Link to comment Share on other sites More sharing options...
KEITHB252 Posted December 18, 2019 Author Share Posted December 18, 2019 Thank you,I will give that a try. Quote Link to comment Share on other sites More sharing options...
