JohnnoK
R380/LT230 balance point
Does anyone have an idea where the centre of balance is on the R380/LT230 combination?
I am looking fore and aft only, not lateral, with the eye to where to hoist it to reinstall. Can it be done via the rubber boot hole for the shift stick or do I need to pull the whole panel out that holds the Hi/Low stick, too?
Share this post
Link to post
Can't help with the main question but if balance and lift height are restricted these things are a great help, a mate of mine made one years ago out of an old transit (I think)  jack and it works brilliantly  level lift bar
Share this post
Link to post
Look at where the mounting points to cross member on the LT230 are. That is where the fore and aft balance is
Share this post
Link to post
I don't think you will be able to lift it at the balance point, through the gear shift stick, although that is described as such in the Haynes manual
I have removed a few D1 gearbox/trfr box assemblies from D1s, but I do it all from the bottom. I have a service pit with a trolley on rails that lifts, and moves the assembly into position
Share this post
Link to post
You are probably right with the tunnel lift, but I am going to use a chain block as primary lifting means through the tunnel hole and a jack for longitudinal correction. I have made up a small gantry that fits over the tunnel and that will hold the chain block nicely over the hole. I took the whole plate out, rather than faff through the gearstick hole, which will help move the lift point towards the TC a bit more.
As for your pit..... bah, humbug! That is on the cards for me, but I believe the Monkeypality takes a dim view of such things.        How is yours built? Bricks or a drop in prefab arrangement?
Share this post
Link to post
"As for your pit..... bah, humbug! That is on the cards for me, but I believe the Monkeypality takes a dim view of such things.        How is yours built? Bricks or a drop in prefab arrangement?"
Dug trench in the ground and built with bricks. Did it many years ago
Share this post
Link to post
Probably  what I will do. There's a bit of an issue with my garage boundary to sort out first... it seems my council approved plans and the inspector coming around and approving my trenches when I built the garage weren't enough and I suddenly find I am a good half meter over the street side boundary....🥴
Where in SA are you?
Share this post
Link to post
Hi John, you can get permission to cross the building boundary, but it is a schlep. I have just gone through the process in Mossel bay
I am staying in Sasolburg (that is where my service pit is)
Share this post
Link to post
