Stellaghost Posted December 22, 2019 Share Posted December 22, 2019 Bought one of these a couple of months ago specially constructed for use with cordless gear I cut a reasonable amount of sheet metal, box etc and this blade is very good I use it with an 18v Milwaukee circular saw meant for wood with excellent results I also just use the bench grinder to sharpen it have only lost one tungsten tip in that time far superior to the evolution blades I normally use and only £19 off Ebay for those of you that cut sheet etc I would highly recommend regards Stephen Quote Link to comment Share on other sites More sharing options...
mickeyw Posted December 25, 2019 Share Posted December 25, 2019 Got a link for these Stephen? I can't find them that cheap in eBay I have a small Evolution multi material mitre saw, and although the blades are good they don't seem to last that long chopping box section. I'd be interested to try alternatives. I think 20tpi on a 210mm blade is a bit coarse for cutting box section. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 26, 2019 Author Share Posted December 26, 2019 Not so good on doing the link thing got blade from folkestone fixings if you put makita b-46296 in the search box it should come up regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 5, 2020 Author Share Posted May 5, 2020 On 12/22/2019 at 4:54 PM, Stellaghost said: Bought one of these a couple of months ago specially constructed for use with cordless gear I cut a reasonable amount of sheet metal, box etc and this blade is very good I use it with an 18v Milwaukee circular saw meant for wood with excellent results I also just use the bench grinder to sharpen it have only lost one tungsten tip in that time far superior to the evolution blades I normally use and only £19 off Ebay for those of you that cut sheet etc I would highly recommend regards Stephen Have mentioned these blades before and have now realised they fit my evolution rage circular saw so just to put things into perspective this morning I have been cutting 6x1/4 flat bar into 2" widths have done 60 metres and blade still cutting well regards Stephen Quote Link to comment Share on other sites More sharing options...
